My new 29” muni from Mad4One arrived in the mail today ![]()
Very nice!
So sweet.
If Midjourney generated bikes like it generates unicycles…
New lightbicycle carbon rim for my 27.5 fixed wheel Muni. Can’t wait to get out and test it tomorrow!
You have got to tell this story?
Wow, that is impressive. Nicely done.
Finally my freewheel hub has become a full unicycle of its own so no more swapping wheels over.
Currently running as a 20" in a 27.5 nimbus oracle frame but i do have a nimbus 27.5 dominator rim that i will rebuild the hub into once i have had some more time getting used to freewheel riding!
Im running shimano m8100 brake lever but need to be careful as the way the bar clamp is on the lever it doesnt allow for much ground clearance on UPDs.
That thing looks so cool!
While it is basically snow free in most of the areas around here now, there are still small amounts of icy snow inthe nearby woods and the tyre I have been using is just 1.95" and has basically no tread. The route I want to do is one I used to do regularly and is half road and half light, easy trails. The only difficulty is that it is pretty steep in parts as it is in an area with some ski slopes. So I have found in the past that this relatively little tyre with little focus on grip is good and light enough but these small patches of snow are just a bit too much right now, so I switched to a 24"x3" Berm Master, which is brand new to me but I found a couple of threads mentioning it. Hopefully this gives me just enough extra traction and volume for those sections.
Left: Nut and bolts that were holding my bearing caps on. Both were a size too big to fit.
Right: Properly sized socket head cap and nylock nut.
Proper Nimbus seat post clamp finally holds the seat in place without it rotating wantonly. Love not having to straighten it constantly. Fusion Freeride saddle is the best saddle I’ve tried so far. 127ish cranks from another random uni. Nimbus pedals for plenty of grippy goodness. The rim has rust/discoloration spots all round it that still needs to be polished off, then “satin brush” it along with the cranks like I did the frame for a cohesive uniform look. 24x1.75 generic tire.
Current state of my WIP Torker “Torkie”.
Following on the black theme and why I can’t be trusted with grown up money:
I made my black 26" (everything but the cranks) carbon build for my travel uni.
I’m using a left over 24" frame but can still accommodate a 2.4" tire or so.
That is a great picture!
Fantastic! I wondered what that saddle is?
It is a bike saddle ISM PN 2.1
I have mounted other saddles of this brand on handlesaddle. They were PN 1.1
PN means Performance Narrow, it’s a relatively narrow range of saddles.
The 2.1 and 1.1 are made in a “40” density foam. They are the softest. There is a model with a “50” density foam, but it has a different shape.
