I had 138 mm for that ride, yes. I think I will be switching between 138 and 117 quite often depending on how steep or technical the terrain is (also adjusting the seat by the same amount).
Since I don’t plan to go full Cédric style, I’m not so worried. I also don’t have any sharp rocks around. I think for muni the light rim helps a lot! Also important for muni is a strong brake. I learnt this the hard way when I ran out of braking power on a steep descent, lost control and had a pretty good crash. I just put in new brake pads and ordered 203 mm rotors
I’m not surprised by the lower saddle - his jumps and tricks are all done seat in and riding off-road with a road-height setup is rough.
I always have mine lower than optimal because occasionally I ride off-road or hop up a curb and it makes it easier.
I think Roger’s comment is about disc on the hub like on this orange M4O 36, Simon @toutestbon did same and I don’t agree with this set up; my view is 100mm wide + disc on crank or 125mm wide and disc on the hub with strait cranks (I don’t like them because of my feet position)
I would always prefer the setup with the least Q factor. And I only use my light 36" on roads and paths.
Otherwise to react to other questions about double or triple insert cranks. When I go for a long climb, I use at least 2 holes (for a unicycle without gear). However, I keep the saddle position that corresponds to the longest crank position on that ride. For the descent, it’s not a problem for my knees to be low on the saddle, there is no force to put on the pedals, just velocity.
FYI, you can run a disc brake either inboard or outboard with any 36er frame, with or without brake tabs. The Dbrake can be used on either the left or right side.
Some things will change. It has VCX+ cranks on for now but these will be replaced with Kris Holm Spirit Disc cranks because it will also have a brake (outboard). In addition this is just an extra UDC Club saddle I had lying around, that I will switch out later. I am also planning to have a handlebar.
I should note that some things were going to be different. Originally I had intended black spokes and black (M4O) cranks, along with a Nimbus Stadium Unicycle with orange hints, to keep the black and orange theme going throughout. However, once I decided to go with outboard disc for braking, Kris Holm Spirit Disc cranks became the only option. Since they are silver, I figured maybe the silver spokes would be better, especially if I went with a Nimbus aluminium hub, which I did. I am not totally sure if that hub was the right call now (I have heard of a couple people braking those alu hubs) but here we are, that is what I did!
Now that I no longer have the pure “black and orange” theme, I doubt I will go with the Stadium saddle because to be honest the last one I tried I did not really like, so… I might as well get something else. I am thinking that through right now. I also have not settled on what I will do for the handlebar.
I have only ridden it around the block once because I did not put it together until very late this evening and it is dark now but… wow it is feels so light and responsive. Like a smaller uni (but faster). This is obviously not just down to the frame. My previous 36er was an all steel (apart from the cranks) UDC Trainer, with the heavier (original) Nimbus Nightrider tyre. This is all aluminium and has the KG Ultimate (light) tyre and lighter inner tube. I have not weighed it but I went back and forth between the two of them in my quick test and they feel worlds apart.
So far, despite not being exactly what I imagined, and not entirely finished, I am really happy with it!
