Super light, 282g per pair.
super slim, 22mm thickness…
Titanium axle and pins.
one piece 6061 body, CNC milling.
sealed ball bearing + DU bearing.
In black color only. [/I]
[I]ECHO seat clamps.
AL 7075 T6 aluminum body with titanium bolt.
For 27.2mm seat post use.
13.5g
in 10 different anodized color. [/I]
These new Echo SL Ti pedals look and feel absolutely nothing like Wellgo MG-Tis. Totally different shape, and a bit lighter and meaner looking.
Worth a shot, the platform seems a bit wider. I held both in my hands and compared.
Brakes-wise, the older Echo brakes from 2008 and before weren’t great.
From 2009 onwards, they have been very reliable. Better performance than a Magura in many cases. The SL brake pictured is better than the TR brake (red pictured) but it’s mainly a case of the alloy used in the slave cylinders. The levers are definitely considered an upgrade over the standard Magura ones though.
Coloured seatclamps ahoy… now you can use 'em on your Koxxs and KHs… even gunmetal, turqoise, orange, purple… all available now.
32 Hubs will most likely get made with in the next year or so, but I doubt the Ti hubs will follow as quickly. I only ride Ti;). I just ordered some middleburn cranks to go on it, I’ll see how they work out.
I’m kind of scared of stripping. If I can find what type of bolts holds on my rear bumper, I’ll change em up to Alu because there is little stress involved.
Ah, spec looks nice, sadly I can’t see the picture as I’m in Beijing currently… Chinese internet is censored so bad I can’t view YT, Vimeo, Photobucket, Imageshack, Flickr… you name it.
Though I wouldn’t mind if you reuploaded it to the Unicyclist gallery
You got rid of your trials uni though? Why?! I seem to remember it being nicely kitted out with the lightest Profile customizations and so on.
Hmm, how much did your SW seat set you back in total?
Looks like good stuff. Maybe I’ll get a clamp if I’m ording it with something else. Maybe a tire (for street), but I can’t find those anywhere anymore in North America…
Sponge! Make another post unless you like the number 666.
I had an Echo brake on my 36 guni. The brake was probably made in 2007 so it may not be representative of their current design. My problem with it is that the brake pads don’t travel enough distance (maybe 3 mm) so you have to set them quite close to the rim. With the side to side slop inherent in the Schlumpf, the rim rubs against the brake pads unless you set the pads far enough away. With my Echo brake, if I set the pads far enough away from the rim then the pads wouldn’t be able to provide enough braking force to be helpful. The Magura that I got from Bryce works perfectly. I forget the exact distance of brake pad travel but it was something like 6 to 8 mm per pad. It made a huge improvement in my braking ability.
I haven’t noticed any difference between the Echo and Maggie brake in smoothness or ability to modulate the braking force.
I hope Echo has addressed that in their current line up.
I love the look of ECHO Components, espiecialy the seat clamp and brake mounts. I want to get them Does anyone know how well the seat clamp holds the post in place?
