Is it just me, or is the only new product the Impulse (nothing against it, I think it is awesome)? I was really hoping for at least some new colors of the Nimbus MUni’s…
ohh..theyre in stock. i had it on email notification when it’s back but i never got notified…hmmmmmmm…to order or not to order. will udc drill them for me if i paid extra or something? i’m too scared to mess it up
With the new releases I was looking at other countries to see what all was new, since UDC US doesn’t have a “new products” page, and got curious about the price differences. Being in the market for a 36”er, I was focusing mainly at the new Impulse and decided to see how the price of it in other countries compared to the US when converted into US dollars. I was a little surprised at the results, and was wondering if there is an obvious reason for the large fluctuations in prices that I don’t see. Are these made outside the US and are just cost more to bring into the country?
I haven’t compared any other products, so this is just limited to the new Nimbus Impulse. Let me know if there are obvious errors, it is midnight here, but here’s what I got using current exchange rates:
Yes you can put a schlumpf is a Nightrider frame, but one with 42mm bearings! You have to bend the frame in to match the hub, then grind off some metal from the inner lip (I use a power file), then tweak the bearing housings to be sure that they are square to the hub.
It does work perfectly well, this is what I did for the LEJOG ride.
Great to see the new products you came up with! I wonder if that new hub would fit my cf frame with shims? Would it be a lot of a weight difference compared to the suzue? And would it hold up to some rooty xc riding?
If I should decide to swap hubs I’d get another rim for it too. Any recommendations for something light but robust that works well for a 2.4" tire?
About the Nightrider for Schlumpf subject: How about making a batch of Nightrider frames that are compatible right out of the box with no additional modifications required? Because I think people are afraid to do it wrong and consequently messing up the Schlumpf bearings. This was my main reason to go for a KH frame.
The handle looks cool too. Will it be available seperately and if so, what would it cost?
No they are not dodgy scales, they are high end Postoffice scales that we use calibration weights to check.
The problem is that there are always variation on the frames. These weights are the actual weights to the gram of the ones I took from the box. When I get more time I will do an average for you.
We have not succeeded in breaking any of the prototypes… even though we have tried! I know they are nothing like as strong as CrMO spindles, they are holding up very well.
The hubs will only fit in 42mm frames and they need to be narrow… so basically they will fit in steel frames if you can narrow them.
