Today I got my seat rebuilt with my welded seat stiffner and post. The seat is so much better! It doesn’t move one bit!
I also lowered my air pressure and found it much easier to do some stuff like 180 on wheel, seat wrap, 180 unispin to 180 unispin, and a little more stuff. Harded to do rolling wraps though.
Me, too. ![]()
Today I finally got in-to-in 3spins. There so fricken hard. I wouldnt stop my session till I go them though. I also got blind 3spins. I think i bent my rim from falling on it so much:). I also had a pretty cool bail. I fell off the unicycle and landed in a perfect handstand.
Well lowering the air pressure caused me to to get a hole in my tube/stem. It is not able to be fixed
cause it is where the tube meets the stem. Now I need to go get a tube before I can ride ![]()
I got that last week. Isn’t it a great camera?
I love it.
Today I went to Bedfords! I got my KH36! I got it with 125s, and Odyssey twisted plastics. It’s so much fun !
Look in post your unis here, and custom kris holm unicycle thread soon ![]()
When I was at Darrens I also saw the new KH Sym Cranks, KH Longneck, KH Double Crown, 08 KH20s, it was a blast !
Thanks Darren! ![]()
Isaac
youre so lucky!!
Well the inner wall of my 08 KH rim is cracked in one spot…
First the frame, stiffner plate, post and now this.
How long does a rim usually last after it is cracked? (assuming I am going to rotate the cranks)
I Think you should be ordering;)
I think I need money.
I got my post rewelded and it seams fine right now… I also got my stifner plate rewelded, feels a little wierd when sitting but it is okay, I got a new frame (under warrenty)…
If I do buy a post it will be a qu-ax ($20?)
And when I get a new rim it will be a nimbus 36 hole ($35+$20 for 14g spokes)
And I might get a Cf base ($100)
good plan!!
Today I got a new tube, and I rotated my cranks. I also rebroke my post after about 5 hours of use with it being rewelded, I can still use the post though because it is broke in the back (i flipped the post when putting it back on), it just feels a little wierd when hopping SiF.
EDIT: I also fixed my seat so it doesn’t feel as wierd, I just have to sit a little more back.
I did a 270 unispin to 180 unispin (on wheel).
My rims are all fairly true.
Also, what happens when a pebble gets jammed in there?
“Tried” (keyword) to grind a a metal bench today with my pedal. I kept slipping backwards.
Finished shaving an old tyre
know i can go down te 15 set
I finally talked 2 of my friends into learning to ride.![]()
I did a static semi-flip and got 12 hops on wheel with the seat in back (name?)
what’s a semi flip? 1/2flip?
yes.
