Not a quick release, more of a one bolt tightening system.
Looks neat, wouldn’t mind seeing something like that on a KH/Nimbus Oracle, esp because the aluminum threads wear fast, so the steel would make the frames more durable over time.
That design would make a QR easier to add as part of the design or to modify to fit that frame…
I’m suprised no manufacturer has used bolts and nuts on an alu frame to save on thread wear. I’ve never had a problem with wear mind but having a hexagonal cutout (frame side) on the bearing cup to slip in a hex nut (so it won’t spin) would fix any issues people are having.
Sounds a bit short to me if no defects. For Al I’ve heard up to two years if ridden hard. Week spot is usually just above the crown, several have gotten theirs rewelded. Never heard of steel Nimbus’ braking.
Any other news of QR bearing holders on the grapevine?
The Nimbus could be straightened and the others possibly rewelded. Might as well reinforce while at it if you take either route.
Only break I’ve seen on KH frames is the neck breaking off the crown. If u still have them take the pieces to a welder and have him put them back together. Newer KH frames are reinforced, 2011+ I think.
Kevin’s Post 228
skrobro’s Post 140
