I’m intrigued to know how it feels going from a G36 to a regular 36er? Any impact on your confidence or was it an easy step that didn’t need much thinking about?
Hope that makes sense.
Ah so I haven’t got my G36er. That’s arriving as a Penny Farthing next Saturday - and this is basically making room for that wheel (my excuse for building a new fixed is my KH frame will hopefully take the G36 wheel)
But this new build is with shorter cranks than I’ve ridden in a 36er before 137s from 150s and the Nightrider Lite tyre is very different. The biggest change for me is the wider hub. From 100 to 125.
I think this is all good practice for when I get, tinker and get the G36er up and running.
All going to be part of my Schlumpf learning journey.
Meanwhile, on the other side of the Northsea; in DK.
This is what I’m dealing with, typical October weather. Rainy and foggy.
I stopped to look at the info plaque but sadly, this being South Africa, it had been vandalised and removed, so I have no idea who it’s supposed to be
The sculpture is named Assemble (by Lionel Smit as @Duff noted). I think it has been wandering around a bit.
I was out yesterday for the first time in months with my son down by the beach.
Good ride if I wasn’t tipping of it every now and again, that’s the lack of practice to blame for that I guess.
Not quite to the level of some peoples riding pictures but I’ve just had a couple of hours in leafy woods with my hatchet at a place I’ve found close to home. Longest trail is about 3/4 mile but there’s many trails that can be mixed and connected giving mix of uphill, downhill, off camber and tight tech sessions which made for a great ride.
Riding trails covered in leaves makes it trickier and definitely is improving my skills.
My niece/sister ride in their skirts (including their failed attempts at unicycling). Good job!
Took my newly built Uni for a ride on some nearby trails. I was afraid that the wide and quite aggressive Bontrager XR4 29x3.0 (approx 1,1kg) would feel either to sluggish or too bouncy at 20psi but to my surprise it just floats over many obstacles without bouncing. I guess it must have fairly well constructed casing/sidewalls that are able to dampen the tire sufficiently. The only downside to the tire so far is that it’s quite noisy on asphalt and it also rumbles quite a lot on asphalt. But hey it’s not designed for that use
I will need to get a better brake. This was just some cheap cheap Shimano brake that I had as a leftover from a two-wheeler but it’s quite weak and I’m afraid it will run out of power on some descents.
Also looking at the picture … I just discovered that this handlebar setup (which is new to me) have a near perfect spot for a bike computer well protected between the saddle and the handles… need to try that.
Bleed your brake, and put some new pads in. I’m sure you will find they work as good as new.
Thanks for the suggestions. They are bleed very recently but the pads could definitely be contaminated. I’ll try to change them.
Edit: Just did another ride (did not change pads yet) and tried to compare the “power” and “modulation” with my other brakes. I think the issue is not really about the “power” but the “modulation” is quite poor on this Shimano brake compared to what I’m used to. Maybe change of pads will still help
Hi hammer , do you know what model number your brake is? I’ve found that some of the base shimano are poor but if you go for SLX or XT they are better.
If your likely to drop it a lot change the lever to either XTR or saints as there more robust.
Another thing I do is set lever clamp bolt to a point that lever is tight enough to be secure but loose enough to be moved by hand so when dropped it just spins rather than brake lever.
My experience has been that all the hydraulic disc brakes I’ve tried have been pretty good and even the lowest level of Shimano components is generally quite functional. The worst hydraulic brakes I have used were still better than the best set of mechanical disc brakes. I’ve had some terrible mechanical disc brakes in the past. Once the hacks that produce cut rate bikes for Walmart and target start doing hydraulic brakes though, I’m sure they’ll manage to make a mess of them.
The brake caliper says BR-MT400. Some entry level stuff / not even Deore The brake lever rattles slightly when not engaged. It feels cheap and not very confidence inspiring. This is not to bash Shimano at all as they also make high quality brakes but this particular model is just not impressive.
Saints is fantastic but also expensive! Not planning to drop it a lot
I’ve ordered a Magura MT5 (4-piston) brake as a found a Black Friday offer. It might be too powerful but then I could swap it with the Magura Sport (2-piston) on my 36".
Some video of today’s ride.
More of me than my daughter as she was enjoying doing the filming. She says she likes watching me fall.
