I switched to a Maxxis Creepy Crawler, after having ridden my Luna 2.5" tire for over a year. I had my LBS order me a replacement tire, and to my surprise the new OEM replacement tire is the Maxxis from uni(dot)com.
I mentioned in earlier posts that I was skeptical about the Maxxis, and the thinness of the sidewalls.
The Luna is by far a better tire. And yet, I wish there was a better tire than the Luna, too.
My first ride around campus, I hated how the tire felt when going up hills. I was out of breath after a short distance!! I was running the Maxxis at the same 29psi (that I was running at the tail end of the Luna’s usage). It felt like I was pedaling a wheel made out of jello!! Very soggy!
Problems:
THIN SIDEWALLS (bottoms out easily, too bouncy so that it feels soggy–I’m now riding it in the 30’s psi, and probably will have to go to 40+psi!!!–the tire also folds like mad)
WEARS TOO QUICKLY (because the tread is almost TOO sticky/grippy for unicycle uses…You’ll have to stay keen on rotating it, probably only after 2hrs of expert-level riding!)
After less than two weeks of riding (less than 8 hours), I don’t think this tire will last beyond three months!! The tread has become SEVERELY worn out, and if I don’t rotate it soon, it will flatspot.
THE VERDICT: This tire sucks! I can’t see it being used for more than LIGHT-DUTY activity…maybe even some small natural trials lines, if you ride with higher psi.
FURTHER OBSERVATIONS/FINAL THOUGHTS: I don’t notice too much in the size of the tires, or the shape. I think the Luna has a nicer tread, wich allows for a more equal distribution of weight on it’s knobs–because there are more knobs than with the maxxis (and it’s knobs are very very soft and squishy). Weight? There is a slight difference, with the Creepy Crawler being lighter. Not by much. Big deal! Since the performance isn’t as good as the Luna, I couldn’t tell at all when riding, because of how thin the sidewalls are.
I’ll be happy in a couple months when I’m back with the Luna. I’m almost positive that this tire is hurting my judgement, confidence, and wasting some of my riding energy.
My height/weight:
5ft 8in
139lbs(probably a little less than that now)
Riding style: Purely Trials, with a few rolling-hops/180’s/2 foot wheel walks now and then)
My uni’s set-up, to give you a clue what I tested on:
profile drivetrain
Jim C. pedals
Alex DX 32 19" rim
KH Pro Canadian-made frame
Thompson post
Wallis de-rail carbon fibre base
SH handle
Miyata bumper
Trimmed KH foam,
Fusion cover.
