Good info Terry!
Now it’s time to present mine!
I probably told that story before, but what happened was that I’ve been willing to get a 125mm hub for my 36" as I think it makes for a more sturdy wheel. So I was lucky to pick up a bargain of Oracle parts sold by @rvs and I was going to replace my hub, fork of my 36" and just relace its rim and have a wider 36. And put the spares on a shelf until god knows when… Then I realized that the spokes sent along the other parts where the exact correct dimension to lace a Nextie! I just needed to go 4 crosses instead of 3 on the Oracle. Add to this that Nextie was still giving a discount and free shipping… I also had a spare saddle, so really the only thing needed to make a new 36" was the rim and an inner tube.
So here we are, finished yesterday, haven’t ridden yet.
I went for the “glossy” finish, to change from the usual carbon look. And got the black decals.
The color is deep grey almost black, but not fully black. I was not expecting this but it’s actually pretty neat. In real life, it’s even darker:
Build is done, just need to true/tension the wheel:
Here’s a weight comparison between the QUAX wheel set:
And the Nimbus/Nextie. Almost 600 grams, not bad!
And finished uni. Wait wait wait, it looks much beefier even though they have the exact same tire - Night Rider Lite.
Yep, still looks bigger without the perspective effect from the previous photo:
Wider is the word:
Let’s rely on science then, let’s put the same amount of air inside both tires and measure:
And yep, on average, the tire is 9mm wider on the Nextie rim.
I guess the Nextie rim being nearly half an inch wider, the tire is more spread. Which also results in a less “pointy”, more round profile. I’ll try to compare the rides, but the QUAX has 150mm cranks and the Nextie has 137. They don’t have an identical setup.
All in all, pretty pleased with the build. The Nextie 36" weights just above 6kg, and I’m sure I’ll get under 6 once I put 125 light cranks and some lighter pedals. It won’t make a difference, it’s just to brag with myself that I have a light 36".
The wheel has been sitting for a week with 2.5bar/35psi without blowing. I went for the 29" inner tube option. And the tire was so hard to put on that I think (hope) it’ll be ok. I don’t like riding with more than 2.5bar as I don’t go very fast. I’m 75kg in total, and the tire hardly squeezes when I hop on the uni. But I have to admit I’m a bit concerned when I see the photos posted by @WeaponizedBacon Scary!
Next… a test ride!
