Okay, so last week, I accidentally tore the valve stem off of my existing tube, trying to get it unplugged with slime. Ended up saving the day by driving out to a nearby Wal-Mart, and buying a ‘thorn resistant’ heavy duty Bell 26er tube. My Muni is a 29er, but after stretching, the tube worked fine, and we had a great ride.
Today I went riding again, out at the same place (notorious for goat-heads), and my thorn resistant tube, got punctured by a thorn. Didn’t have the time to try and patch the tube, and ended up sealing the hole with a dab of rubber cement from my patch kit. Worked like a charm, and it’s still holding air.
The problem is, it’s still holding air . I got home, and removed the tube to patch it, but now I can’t find the puncture to repair it. I threw the tube back in and pumped it up, but I know I still have a hole in it somewhere that could start leaking any time.
So what I want to know, is whether or not tubeless is worth it. There’ll be a high initial cost (new tire, tubeless kit combined with poor unemployed high school student) that’ll put fixing my brake on hold. I guess what I’m trying to find out, is what are the cons to tubeless?
Then, if I do go tubeless, what set up is best for a 47mm wide Dominator2 rim? Would one of the stans kits work? Or would ghetto be better? Or would the ‘6" section of tube with valve stem/strapping tape or tubeless rim tape’ set up be best?
I know that if going tubeless was cheaper, and I knew it’d stand up to multiple thorn punctures, I’d probably do it.
Or should I quit complaining and stick with tubes?
Sorry if I’m asking some questions that are really more personal preference than anything, just thinking aloud…
