I think that shoes [maybe] would have a lot to do with it. The more beefy the sole and more support the better. Tennis, running and other light weight shoes may not cut it if you’re doing big drops, etc. I wear hiking boots and have had no foot-related pain doing 4’ + drops. I thought about adding a padded insole but haven’t really needed it yet.
Hey Miles, I feel your pain, literaly. I too have suffered much at the hands of bruised feet. There are three ways to help prevent it from happening, but none are perfect.
As Terry said, get shoes that have a very stiff and very strong sole. I found when I was doing drops like that I was actualy busting the plastic supports in my shoes.
Get some pedals that have lots of contact areas with your feet. Odysees have three contact areas where the pressure will be applied
_______
[_______]
They look like that, if you can get something that looks more like this:
_________
[]_[-]_[]
it would spread out the impact over a larger area. I have gotten some new pedals that do that, and I find it helps alot.
Last but not least, is to just not do them. Although they look cool and they are alot of fun, large sets (anything bigger than a 6 set in my mind) are really hard on your body. Once you can do them, have them on video even and have shown your friends, I would save them for special occasions.
Some couple smaller tips are to roll out more, use larger cranks (put less pressure on your back foot when you slow down on the landing), jump less vertical, and always make sure your feet are fully healed before doing it again, even if you have changed equipment.
I found when I first hurt myself I would give myself a couple of days until the pain subsided from walking, but I would go and hurt it instantly. It is sad but you really have to give yourself a good enough break to fully heal.
I hope that helps, and isn’t too much of an essay for you,
what shoes are you using? anything that’s a really felxible/thin sole will cause your feet to get beaten up. stiffer/thicker soles will protect your feet.
hmm never mind I sudenly don’t want them. I made a thread on some plastic ones a few days ago, I think they have a pretty big surface area. I’ll go check…
You can grind without a grind plate with metal pedals with no problem. You just need to remove the pins. I find magnesium pedals even slide better than plastic.
I’d say something about tire pressure but you probably already have that where it needs to be. I’d say something about losing weight but you don’t have any to lose. I’ve been on the lookout for some non-cleated cycling shoes for a while now. Something with a non-flexible sole but a grippy base. Regular shoes are made to be flexible.
Those are very cool looking pedals in the previous post. Heavy?
What’s your foot position when doing drops? Ball or center of foot? Where do the bruises occur?
I’m using some skateshoes right now, and Ive actually been replacing the soles because they seem to deteriorate. I might try one of those gel sole pad things.
In addition to the other comments, consider getting a set of 661 lace-up ankle guards. They wrap around your arch with a tough cordura-like fabric and give some good arch support and, of course, ankle support. In any case, they should help with bruising. No guarantees, but I have had good success with them myself, and think they would help quite a bit.
Not that I’ve found, for off-road and that kind of stuff. They do settle in a little, and also you have a lot of control with the laces. Note also that they do serve in some capacity as ankle guards, since both sides have not-really-padded stiffeners with ankle bone cups. The other cool thing is that they take up almost no room in the shoes.
I haven’t really tried them with the freestyle unicycle, but for freestyle I’d probably want to have more ankle freedom, at least for wheel-walking and that kind of stuff.
