Latest idea in wheel weighting
After some more riding, I have determined that adding weight to the wheel of a 36 commuter creates a useful fly wheel effect. There is a better way to do this then ankle weights, though less convenient for experimentation
Stick on lead wheel weights, available here..
The amount of flywheel effect created by adding weight to a wheel is determined by only 3 factors.
1 The amount of weight added.
2 The distance from the center of the wheel.
3 The velocity of the weight.
The last 2 factors are of greatest relevance, because inertial energy increases with the square of velocity. Energy = mass x V 2
Eric should note that the ratio of weight added, to the original wheel weight, is not a factor. A basic understanding of the physics involved would show that a great deal more weight would need to be added to a light trials wheel, then to a heavy 36 wheel, to achieve a comparable flywheel effect. It is for this reason I expect all experiments adding weight to <36 wheels to be
fruitless.
I plan to see if I can add these weights to the inside of the rim. Because this location is a few inches further from the wheel center then is achievable with ankle weights, I will need a bit less then 3 lbs. to achieve the same effect as 4 lbs in spoke wrapped ankle weights.![]()
On my test rides, I noticed that I rode until I was tired on both the light and heavy setups. They both felt the same to me, I have determined that my testing cannot measure the difference in effort needed between them. It was to small to be noticeable to me. Actually, my ass gives out before my legs, unless I am riding muni.
