it says the Qu-ax has 42mm bearings and the Nimbus II frame fits 40mm bearings.
Is there any way I can make it fit?
My onza trials has 42MM OD bearings, and a (factory powdercoated) nimbus II frame, and it fits, but isn’t optimal, i can barley put the nut on the bolt enough for it to hold (in other words, it goes trough the nut, but no more)
Never had any problems though!
thank you
You should be able to get some slightly longer bolts from your local hardware store. This may be a good idea if you are worried about the bearing holders staying on.
