πŸ“œ [Wiki] Share files and links of 3D printed unicycle stuff!
Here’s a wiki to directly upload the files or share links of 3D printed unicycle stuff.
Forum uploads now accept the following file extensions if you want to directly upload a file (4 MB max):
stl, vrml, obj, stp/step, 3mf.
:information_source: Reference topic: Show Off Your 3d Printed Unicycle Stuff!
Brake
Lever Grip (@Medaceina)
:file_folder: https://www.myminifactory.com/object/3d-print-unicycle-brake-lever-grip-158631
Triangle brake grip (@Medaceina)
:file_folder: https://www.myminifactory.com/object/3d-print-unicycle-triangle-brake-grip-159957
Pedals
Pedal plugs (@Medaceina)
:file_folder: https://www.myminifactory.com/object/3d-print-pedal-plug-158315
Saddle
Rail mount saddle bags (@mowcius)
:file_folder: https://www.thingiverse.com/thing:4932460
Frame
QX-RGB Bearing holder washer (@finnspin)
Find the files and description here:
Mad4one Bearing holder washer (@finnspin)
lagerschalen_spacer_2_6mm.stl (92.1 KB)
Fine tune the thickness of these washers either by scaling your print in the z-axis, or by sanding down the printed out ones. You want the bearing to turn freely when you fully tighten down the bolts with these washers installed, but also no play between the bearing and holder.
Feel free to add content yourself! :handshake:
@finnspin > Seems like you have something to share here :grin:
