Hey there Douglas,
Thanks for watching I’ll be hitting the streets again real soon.
Hey there Douglas,
Sorry to hear that yeah we for sure have to be careful with shoes that have laces… Keep riding and be safe.
Putting unnecessary sharp spiky things or jagged surfaces on sports equipment is just one of those things that common sense should prevent. A saw blade disc makes about as much sense as dagger tips for your bar ends or winding barbed wire through your spokes.
Saw blade disc “might” look cool to a few, but its an idiotic consumer product. Working in mfg I can only guess that some salesman had a “bright idea” to “re-use” an existing saw blade cutting tool for making unicycle disk brakes. Also, the sharp corners and points are stress concentration points = would break very easily. Nice product QU-ACK. You hurt people.
…slam
The 1% of times i misjudged freemount…and metal pins on pedals scraped across my calf.
Scabbing up nicely after 4 weeks.
I unscrewed the pins off the Wellgo pedals …still got plenty of grip for hopping and hill climbing
Ouch, but if that’s your worst injury, you are doing well
Totally!
I put a set of vibram rubber clad pedals on my wifes hybrid bike. I used them onba bike tour last year and found them quite comfortable for all day riding. I have been tempted to try them on my 29er road uni.
The rubber is quite grippy. It just seems a little safer.
Note the ones on my wife’s bike are a little different and we’re not so expensive. I bought them at dicks sporting goods in Pittsburgh. If I by another set I would like the set I posted.
That seems interesting. My issue with pedals with pins is that they destroy my shoes very, very quickly.
To POKALDE.
After a few pedal lacerations(4x claw rips). I experimented a bit by removing “most” of the studs, but leaving a few towards in cranks side. That might help you.
Also, you might just consider “changing back” to standard single hole cranks. I have a 3 hole cranks and guess what? I never ever change the pedal position. Why?
a.) I know the feel and control will change. Abslutely, and I won’t waste time/injury to experiment on this. Since, I also like to do SIF and backwards I won’t risk it.
b.) The extra “sticking out” of the crank end = a tripping hazard. Unless you place your feet on the pedal “wide” you cannot avoid a possible bumpiong. However, feet wide on pedal= slipping off. Thus, using the “inside hole” of a multi-hole crank = lose + lose situation. Unless you are just riding for distance on a flat.
I know I have a 3 hole crank but I don’t use the other holes, what a waste. I once had a dream that I could do both freestyle and long distance…but on a 24"? It looks cool, I guess?
Also, if you ditch those pedals and get a proper plastic pedal like Fyxation. There are raised plastic studs, which do a good job of gripping. Unless wet or muddy. Also, they will “tear your skin” if you touch them on a fall…however, not as deep as the surgical cuts from the aluminum studs. So, riders need to keep that in mind.
enjoy…
You could also try the slightly more aggressive version of the pedals linked by @Bug72
I used the Geo Trail for some time and they are nice in the dry but as soon as they get wet there is not much grip so they are now on the wife’s hybrid electric bike and I just accept the risk of riding metal pins. And if planning something risky I wear shin protection.
Yeah, Im happy with the wellgo pedals with pins removed. The plastic grippy spikey bits are pretty good… and intetface with my shoes well.
Been enjoying hill climbing yestetday and pedal traction was no issue.
Ive been measuring grade by spirit level and tape measure.
If you happen to have a smart phone there are apps that will measure the grade very easily.
What apps do you recommend? Strava is pretty useless as it averages grades per segment as defined by strava.
It would be good to have an app with the function to select start and end points to measure grade.
On a couple of hills I am trying to ascend, the grade varies and there are some spots (say a 5 meter length) that is a challenge and I go back and measure manually using a 300mm long spirit level with tape measure for vertical
30mm vertical = 10% Grade.
45mm vertical=15% grade.
By the way, how could I have quoted JimT and replyed in a new thread?
I use a free app called Bubble Pro. Simply align the phone with the grade and it will show a bubble and the grade in percent.
This shows a 12.6% grade on my driveway. On a very rough surface maybe a small stick/straight edge may help to average the surface out.
Highlight the text you want to quote in the original message and an option will pop up that you can click on to “quote”.
You can define your own segments anytime, I’ve made many, they have to be a minimum distance now which is pain. It is more suited to longer distance segments (like Lycra warriors would use for TT) than measuring short sharp slopes, but we are talking GPS/phone not surveying equipment. Of course it is an average grade, the slope varies all the time. For segments were there is a steep section, followed by flat, then steep again (like in LCNP), try to create two segments of just the slopes.
I rode Muni with my Safety Shoes. Haix Black Eagle and there well for ride Muni and for Work. They have a good ankle support.
But my Pedals also scratching my waten . The Wellgo Metal Pinns are not so high but aggressive and I’ve some holes in my waten. Yeah not so nice but it’s goes.
I had a pretty nasty fall my foot when in the frame of the Nightride uni and twist some ligaments in my knee it took me 3 months to heal.
Apparently no one’s got bad injuries in 2023
Well not me, In Spring I face planted while riding my 36er at 20km/h+. Got some 20 stitches on my face and a nice scar. It made me hesitated to ride a 36er for months, and it was only until the autumn I pick up steam again.
What I’ve learnt from this incident is, be awe to your newly acquired power. I was really new to the 36er (well, new to unicycling in general) and discovered I can ride really fast on it. Without the skills to handle the unicycle and proper protection, I pushed myself too hard for pursuing speed, they all made a bad injury an inevitable thing.
While 2023 was accident free, In 2020 I broke several toes when my worn out vans shoe slipped off a pedal jamming my foot into the ground breaking several toes. The reason Im bringing back ancient history is now as 2024 is around the corner with the damp cold winter weather in the air that injury is causing me residual pain.
In the new year stay safe, keep your equipment in good condition, wear PPE and keep those shoe laces tucked away.
Happy riding in the new year.
