you could make a custom trials uni.
something like
bedford frame - around $40
KH moment hub/ cranks - like $130.
VHI 48mm wide rim - $45
snafu pedals - $30
KH street seat - $55
seatpsot - $15 to $20.
- wheelbuild( probably like $30)
something like
snafu pedals - $30
like $340 total give or take.
I though Qu-Ax could come with 127s? You just had to tell them that in the order.
145s are actually good for trials. Youll have lots of control/leverage.
Yeah
nimbus II frame-$35
kris hom movement hub and cranks-$136
NImbus trials rim-$35
Odysey twisted pedals-$11
seat post-$15
Schwin/nimbus gel seat-$39
Wheel build $20-$50(or do it yourself)
$270-$320
That’s what i would make up.
KH moment bearings are 42mm OD and nimbus II frame is for 40mm OD.
any good trials frames with 42 OD bearing housings?
KH or Koxx.
Nimbus II frames can hold 42mm bearings. =p
EDIT: you guys are forgetting about shipping in your price.
are you sure about that? cuz they say they are 40mm
the bearing holders on the nimbus are 40mm.
they will fit a 42mm bearing though. my mate did it with his and it was fine.
are you 100% sure this is a life and death answer
yes
it was a nimbus frame with 42mm bearings.
he had no problems with it, he put a little bit of rubber in the bearing holder so that the bearing would have more contact with the holders.
if you understand that
can anyone else testify to this?
I made a thread asking about it. Look a page or two back.
A reply from UDC.
KH Moment hubs are 42mm, and the Nimbus II frame is 40mm, but because the Nimbus frames arent machined made to have perfect bearing holders, they can hold bigger ones.
A few people on this forum have been running this set-up for years now, doing muni and trials and its fin.
I will be buying the KH 2007 moment hub to fit into mine in about a week.
