Okay, so a little revision:
I don’t really want to get all crazy with seat choices, so I’ll have to see how this goes, I’m mostly doing this to help out the folks who don’t feel comfortable doing it themselves, so if you have the skills then you ought to do it yourself.
First run I’d like to limit it to ten seats, so the first ten who sign up and confirm their decision will be all I do for now. I can’t afford to be stiffed, so if you tell me you are in, then you’re in.
As to seat choices, well, if you like a certain seat now, then that is probably the one you should get as a flat seat, however, in my experience some seat pads work better than others. If you have questions after reading though all the posts in this thread, then ask here and see what others think.
Currently I run a Nimbus Gel and two KH Freeride (one stock, one modified). The Nimbus Gel is not bad with a padded bike short, but it is not as comfy as the thicker stock KH Freeride foam.
In terms of cost, a Nimbus Gel seat is a better deal, esp since the KH and Nimbus use the same base, BUT keep in mind that the Nimbus cover is stapled, so you will either need an accessory aftermarket cover (more $$) or you’ll need to staple the cover back onto the seat. I’m not stapling covers, nope, ain’t gonna do it.
So for now I’d prefer to stay with KH seats: Street (gel), Flat (minimal foam), and Freeride. FYI, the KH Flat is the same as the Nimbus Narrow, the KH street is the same as the Nimbus Gel, there is no Nimbus equivallent to the KH Freeride.
Example:
- Your Name, Seat Style (Freeride, Street, Flat), Color (three choices).
Your cost is whatever the seat costs plus shipping.
