We say a top of the line unicycle is cheeper than a low end bike. True, but how expensive could you actually make a unicycle. Post what you can think up and how much it would cost. It doesn’t have to be mainstream components but as long as you can buy it somewhere it counts. Geared carbon fiber 36er?
Anyways, post what unicycle you would buy if you had thousands to spend on it.
I already have close to it, but it depends if you mean building with readily avaiable components or making your own.
Off the shelf, this is similar (but slightly lighter) than my current build:
Triton 29, disc tabs, Flatfish seat, Spirit cranks (disc compatible), KH Moment Ti hub, Mavic TN719 disc rims, WTB Motoraptor 2.4", FOSS tubes, optional XT disc brake with Starfighter, Thompson Seatpost mated to a KH interface, and whatever lightweight pedals are trendy at the moment.
It would be easy to list the most expensive part possible for each and every parts in a unicycle and make the sum.
However, I am not sure that all the parts listed will make a consistent and desirable unicycle
Saddle: a thick carbon base coupled with a high-end foam and/or gel. Not sure it is mainstream but we can quote the most expensive saddle + carbon base
Seatpost: a Thomson dynamically adjustable version for example (listed at $449)
And there is the problem of the disk brake system because neither the Schlumpf nor the Mad4One cranks support disk braking so it would require not going for the most expensive in one category
Saddle: a thick carbon base coupled with a high-end foam and/or gel. Not sure it is mainstream but we can quote the most expensive saddle + carbon base (not sure on this one)
Seatpost: a Thomson dynamically adjustable version ($449)
Rim: A DT carbon rim ($957)
Cranks: Spirit dual cranks ($120)
Disk brake system: A Formula One special edition kit ($720)
Honestly if I had thousands to spend, I would probably not try to build the One Unicycle to Rule Them All. I would probably take the Nurse Ben approach and try every piece of new gear as it comes out, and continually be building and rebuilding unicycles with new bits and pieces.
I wondered the same thing and did some research. Apparently it is a one atom thick sheet of carbon in a hexagonal pattern. It is supposed to be about 20% stretchy, completely flexible, conduct heat/electricity better than copper and be incredibly strong.
To be honest, we seem to be taking the wrong approach here. I have a basic nimbus 24 inch unicycle that I’ll sell for 50,000 usd or best offer. If you purchase it you will have the most expensive unicycle.
You guys are thinking small. I’d start with a frame and wheel made of ‘unobtanium’, the anti-gravity mineral from the planet Pandora. You would still have to balance yourself, but the weight would be considerably lessened. Coat that with a layer of the precious metal of your choice, such as gold, and encrust that with diamond bling.
The seat should be upholstered with the most expensive, most politically incorrect fur available, such as baby seal or something. Inside would be an electrically powered massaging system to keep your circulation going (as if you would actually ride this thing for more than a few minutes).
Add an electric motor and power system for when you get tired. And of course, use the most expensive parts on the market, just because you can (in this fantasy).
Finish with two tiny cherubs to fly around you as you ride it.
@ John, I like the cherubs, but I’d more inclined to have some wood nymphs
Well, if cost was not an issue, then I would invest (millions?) in a variable speed hub like the NuVinci, with a gear range that is remotely adjustable from 0.5 : 1 to 2 : 1, and of course it would have a disc brake
I’d also get into tire development and work on creating uni specific tires.
Better/More expensive yet, Engineer and custom build to your specification, your personal Uniride. The time without it as it is made seems to be the most valuable.
