Yeah, it says it should be ready in about 110 minutes! Man, you gotta youtube it. Besides, the volume can’t be adjusted on vimeo! I can adjust volume everywhere else; youtube, google, whatever, except vimeo!
i know but my computer stinks so bad that when i upload somthing to youtube its like error 5456633 ( i just made up the numbers just to let you know;) )
This is just how I do it, I jump hard down to get bounce out of the tyre which allows me to jump higher more easily and I seem to have more control that way. You just jump off the uni without using the bounce off the tyre to boost you up. Try jumping just as you bounce off the ground, it might help.
From what I can see, you’re not making a committment to the landing. You don’t believe you will succeed so you’re heading for a bail before you even find out. Try making the landing (on the cranks or pedals; I learned it to the pedals) and then jumping again to get your feet (and crotch) free. When you hit that landing you’ll know if it’s something you can hop out of or not, but the “safety” jump should eliminate some of the scary part.
O and jump a little higher, I practised 180 uni spins for ages, not really making any progress. Then I jumped a little higher and they were easy after that.
