I’ve been thinking about this for a while, and can’t figure out the logic behind seat angle adjustment on a unicycle.
When you sit down, the seat should find some equillibrium with your buttocks/crotch.
It doesn’t matter if you have the seat angled upwards or downwards or flat, what you change is the angle of the frame underneath you once you sit down.
Why add extra weight and complexity by having angle adjustment (either by having curvature or a complex bicycle angle adjustment system)? You could also have an integrated all in one seatbase/seatpost that would save weight.
More importantly, for short people, it decreases stack height and means you don’t have to cut down the seat tube as much.
Your center of mass must be in the same line as the axle of the unicycle and the center of the saddle. You can adjust the angle of the saddle with respect to that line and it shifts the position of the force distribution on the saddle. I think what you’re missing is that if the rotation of the saddle only affected the angle of the frame when you were on the unicycle, your center of mass would no longer be directly over the axle.
Your centre of mass should be over the axle whether you have the seat at +45 degrees or 0 degrees or -45 degrees with respect to the frame.
Once you sit down and start riding, the centre of mass and the saddle angle are constant, what moves is the angle of the frame (depending on saddle tilt with respect to the frame).
On a bike, the saddle is fixed at an certain angle to the ground, because it has two fixed points (both wheels) stopping rotation of the saddle. On a unicycle, the frame rotates around the axle so whatever seat angle you start with is irrelevant once you sit on it and start riding.
But from the limited tilt I can get with a unicycle seat, I haven’t noticed much difference, except in how much my thighs rub against the fork crown.
If you notice any difference, it must be because you are taking extra weight with your legs. So at the extreme, if a seat was completely vertical with respect to the frame, someone would have to stand on the pedals in order to ride. But that means it’s no longer a seat- it’s an ultimate wheel with handlebars.
Hi GizmoDuck
I"ve been trying to ride for just over two years now. This is the angle of dangle of my seat. I find this position the most comfy. I can sit in the saddle for about an hour and a half before feeling any discomfort. Hee hee, you’d think with it angled like that I’d be an expert at dismounting backwards gracefully :p, but no such luck, not yet anyway.
I don’t know for Tour/Muni riding, but for Flat/Street you will see riders with a lot of different angles, which all have their pros and cons. If the front of the saddle is really low, it’s much easier for Flips, but harder for roll tricks and Unispins, when you put your seat in a “normal” way or with a pretty high front part, you have much more stability and control for SI riding, and it graps better for rolls, but there is a higher chance that badly landed Flips may hurt, and fliptricks are somehow harder..I can’t really explain why, it has something to do with the way you can pull/push the saddle.
If you could not adjust the angle of your saddle relative to the seat post:
You could adjust the angle of your saddle relative to the ground by tilting the frame back (or forwards) beneath you as you rode.
This would indeed get the saddle at a comfortable angle for your backside.
However, it would also put your hips further back (or forwards) which might mean that your legs were in a less comfortable position for pedalling.
Also, if your hips were moved a few inches backwards, relative to the tyre’s contact patch with the ground, you would need to lean your upper body further forward to compensate. Otherwise you would simply tip over.
So to get the saddle at a comfortable angle, you would end up with every other part of your legs and upper body being forced into a position to compensate.
Or you could just do what we do: adjust the saddle to an angle that is comfortable for your butt when you are in a comfortable riding position…
Sorry, I’m not sure I understand what you are saying?
The angle of the frame automatically adjusts to the angle of the seat, not the other way around. ie the saddle angle (with respect to the ground) and your centre of gravity when riding are constants, the variables are the frame angle.
I also suspect that what people get when they adjust seat angle is not so much a change in seat angle (with respect to the ground) when riding, but a height adjustment.
Perhaps that is what is noticed in terms of comfort or handling, but you might get the same effect from raising or lowering the seatpost.
Yes, but how do you get your centre of gravity over the axle if your arse is 3 inches further back? By leaning forwards.
It’s all about what you would have to do to your entire body position to get your centre of gravity back over the axle if you tilted the frame/seat backwards as a means to adjust the angle of the saddle.
If the saddle moves backwards, your arse moves backwards with it. If your arse moves backwards, then something else has to move forwards to compensate.
So from T to T, if you assume that the saddle will stay the same angle to the ground or wheel axle, you would either angle your body more if your buttocks were fixed to a certain position on the seat, or shift your position along the seat.
However, you could have a seat that allows simple forward and backward adjustment, and that would give an equivalent effect to saddle tilt.
Yes. But given that seats are all curved, moving the seat forward/backwards means changing the angle between the nose and the pressure point. Its just semantics.
And seats vary in width, so moving the seat forward/backwards allows one to find a spot that matches the width of the sit bones more correctly.
At a standstill on flat ground, your body will balance on the unicycle best in a neutral position, which is when the frame is perpendicular to the ground, so adjusting the seat angle relative to the frame will help you achieve your individual neutral position based on where you seat on the seat, how your posture/body type weights the seat, and the terrain your ride.
I have adjustable seat posts on all my unis, and through trial and error I have adjusted my seat angles to positions that are most comfortable, ie minimal taint pressure, comfortable jewels, moderate pressure on my sit bones, and ease of movement on the saddle.
Now if you want to say it doesn’t matter, that’s all fine and good, and maybe the lot of us are princess and the pea types, but I can tell a big difference when I’m setting up a new seat.
My XC unis tend used to be set up flatter than my DH unis, which makes sence based on terrain choice, but over time that difference has become less and less, so now all of my unis are set up so that the butt pad portion of the seat is perpendicular to the frame.
I think Mike’s pics tell the story, good posture and good balance go hand in hand, so adjusting the seat helps the rider individualize the uni for better balance.
In my #14 post, I see what Mike and Harper are getting at, but the effect you get from tilting the seat is the same as adjusting the seat forward and backward (horizontally).
If you got rid of the curvature of the seat, and any hardware related to angle adjustment, you save weight and reduce redundant seat height (important for short people).
Having forward/backward seat adjustment is less complex than angle adjustment.
Yes, that would be a nice option, just like a bike. You have some fore/aft positioning on the fixed posts, but still not enough.
I have a stack of minicell foam cut ups where I mocked some seat designs, but after a bunch of tries I could not get close to the comfort of the KH Freeride. I think the movement of the pelvis on a unicycle seat is significantly different than on a bicycle seat, so flat might not be all that great.
