Help! What type should I get? Do I get the Nimbus nd a UDC gel saddle or just the Qu-Ax?
qu-ax is stronger of coure cauz it’s splined…
so u think qu-ax? coz if i get the qu-ax it means i dont get the UDC gel saddle 4 the extra comfort!
no big man… the other uni will snap like ass on a 4 ft drop… the qu-ax will hold up pretty nice…
Just do a lot of SIF trials, then you wont really need a comfy seat lol
k
thanx man
ny more thoughts on the subject are still welcome ny1!
Yes, are you considering the qu-ax 20-inch cross unicycle with the red hub or the splined trials version with the yellow hub? The cross version is $10 more than the nimbus trials and the qu-ax splined trials is roughly $100 more than the nimbus. If you are debating between the unsplined cross qu-ax and nimbus then I would opt for the nimbus with the gel saddle, otherwise go for the splined qu-ax.
P.S. The splined qu-ax trials uni is no longer listed on UDC, does anyone know what is going on with that?
the qu-ax for shure
yeh its the splined one. So what is this SIF thing i keep hearin about?
Seat-in-front, it is typically used in trials for better hopping height.
ohhhhhh, i get it now thanx man
yer, brownboy, just do it to piss off chris
The qu-ax is heaps better. the nimbus is almost the same as yours, just a different wheelset … and seat…
Ed
qu-ax for sure. the seat it comes with is still comfey, just not quite as comfey. it as also much, much stronger. i think they are in stock at unicycle.com australia. if not, guy will be able to get one in for you.
cheers,
Max
i have the nimbus… its done me ok but im light and dont do massive drops or even big ones??
the hub is better o the qu-ax sooo id go for that 1
Just buy the Qu-ax trial uni (the one with the yellow axle)
I know somebody ho owns one.
Its a very strong and light uni.
yeh i think i will get the qu-ax thanx evry1:D
good choice
It would be a better idea to get the yellow hub qu-ax even though it might be a bit pricier because you’ll end up replacing parts for the nimbus so it’s a better deal in the long run.
i really dont like you brown boy!!! so get a jugglebug 4 SURE!!! heh, NOOB!!!
