Gearing up for the 2022/23 Schlumpf arrivals it occurred to me that perhaps having a dedicated geared-up-gallery would be a good idea.
We can include previous, older Schlumpf builds - as well as the spiffy new ones as they get built this year.
To mods: if you feel this is too much fragmentation for the forum - please move this post to the general “post a picture of your unicycle(s)” thread
To kick this off - you’ve seen it before, but I would now hazard that this G26er has reached its final state. I’m happy with all aspects for the build and it fits the era of the hub and frame style perfectly.
Love the Ursli-Bar with real leather in yellow!
(And thanks to @Dino for the stiffener plate - it enabled this to be classed 100% complete!)
Looking forward very much to seeing the new geared rides that roll up on this thread - as well as seeing (if you feel like sharing) what people already have in their two-speed mono-garage
Posted in another thread but 29 x 3.0 build was a handle and air saddle. The build is for Unipacking trips this upcoming summer as my regular 29" tops out as 15-16kmh average. Plus this is my first ever bike or uni with a carbon rim. I think it’s quite literally the highest end uni I could get with the exception of a custom frame but I’m so excited to ride it.
Not pictured are the MTB knee pads, 5/10 shoes, and elbow pads as I had quite a few bad crashes this past summer and I’m expecting the G29 to have a few as well so pads, good shoes, big tire, long cranks,and a handlebar to hopefully give me as much control as possible.
I’ve also honed my gear to get my pack under 15-18lns with food hopefully and I’m aiming to lose 10 lbs before the season starts to make pushing this 20lbs uni a bit easier on long days of trips.
It’s the Qu-Ax handlebar. I’ve tried this, the KH one and a custom Flansbberrium one. All good but I like the different hand position for the one and the ability to stretch it out a bit longer. The other ones I found would commonly twist the seatpost when they fell and the bar ends on them would get chewed up quick. This one requires less adjustment and the BMX grips on it can take quite a beating.
Sadly it’s not as cheap a solution anymore. It was a mud guard and one of the ones that goes in your seat rails on a bike from Decathlon but the price has doubled for both recently so it went from a $9 total solution to a $20 solution which is the same as a clip on fender.
I ended up going through several clip on fenders 2 winters ago and found out you don’t need to make it really tight on the frame, if it can rotate a bit of will turn instead of breaking in a fall. So my other 29" has just a clip on fender.
It has been rebuilt yesterday so I have not put a lot of kilometres on it. But it looks like it’s a wonderful beast
BTW, I have only 3 buttons for my 2 Schlumpfs because I lent one to a friend… So I have ridden only in high gear since yesterday. I’ll try to get my 4th button in the next days so I can finally have my 2 wheels usable at the same time!
I’m curious how fiddly it was to get the rotor section off. I am hoping it can be done with varying sizes of metal drill bit, as I still haven’t invested in a dremel (silly - I’d use it!)
Contemplating moving my 200 series hub into a BF equipped 27.5” ride…
That was tricky. I didn’t have the tools myself. So I had to find people who had them. Then, we found out that the rotor was really sturdy. It took us a long time and lots of effort to get the section off. Maybe we hadn’t the exactly right tools, not sure.
Once we had the section off, I haven’t paid attention to the irregularities of the rotor, where we had drilled it. And I hadn’t any tools to fix that. So I have used my 2 rotors that were not sitting flat for a while. Until I got a Dremel a month ago!
Allright I’ve had a disc on my hub for years, probably the first ever on a schlumph. Also it’s on my old square taper so it is a great ride with a well modulated brake. Original 29er.
