Fat biking seems to have just taken off in the biking world. are we going to be left in the dust?
A lot of the earlier adaptors were turned off by the slow handling and square profile of the Endomorph tire. 2 years ago Surly introduced the Larry tire which changed things significantly but we still had very limited choices when it came to tires.
In the last month or so the number of choices have almost tripled, with offerings from Surly as well as a couple other companies.
We started off with the infamous Endomorph 26x3.7, a high flotation tire with square profile and low tread
Then came Larry. Larry changed the fat biking world by giving a fat tire a rounder profile and decent grip. Designed to be a front tire it also works well as a unicycle tire.
Using the same carcass Innova released the Spider 4.0 tire. Meant primarily for fat beach cruisers etc. Not too much is said about this tire, it is generally a cheeper alternative to the Surly branded tires and has a perfectly round profile.
Then Surly did the unthinkable, in an areana that had only a couple tires they went and offered a bigger fatter tire for more float, a chunkier more aggressive tire, and a nice smooth road tire for those rolling on the flat top.
I will start with the Big Fat Larry, or BFL. BFL is basically a bigger fatter Larry, as the name suggests. still the same pattern as the “smaller” counterpart but a little bit wider and miraculously lighter as well. It should fit in a Oregon frame but I don’t think anyone has tried in a Conundrum or Triton yet.
Big Fat Larry 4.7:
Next we have the Surly Nate, same size as the original Larry but bigger chunkier knobs for those who want big traction with the big tire.
And finally from Surly we see the Black Floyd. Another tire coloured piece of brilliance for those who want to ride the fat without all the knobs and rolling resistance.
Just when we thought we were done a couple more companies come out with some new fat rubber. North 45, another QBP company (Surly is owned by QBP) has also announced that they are joining the party with the Hüsker Dü. Looks like it would be great on a unicycle with more front back traction compared to a Larry but not as aggressive as a Nate.
And now it looks like V Rubber is also jumping on the band wagon with a 4" tire, and this looks to be the first fat tire that isn’t made by Innova. It is supposedly heavier than the other tires but should come at a lower price point.
Looks like a decent tread pattern.
With all these options available to us it might be time we get some more choice of unicycle frames to put them in. Of the tires listed I have only used a Larry but I think that the tires above have huge potential for downhill, XC, loose condition, and winter riding.
There is an explosion of new fat bike frames, will unicycles fallow their examples?
