New old stock silver Magura 2004 HS33’s, $100 per wheel
Every once in a while I come across a stash of brand new 2004 HS33 brakes that someone tucked away for a bike build that never happened or a bike shop that is selling off their old stock of Maguras. Even though they may be 6 or more years old, they are still new and should give you thousands of miles of solid braking on your unicycle. Lever blades are compatible with the KH Spooner lever extension
I sell the most 2004 HS33 brakes to unicycle riders because they seem to fit the best under the unicycle saddle, the compact lever with its red TPA knob is easy to reach for most riders, and the lever body itself can take more hard UPD hits than the more fragile 2005-2010 HS33’s. I run 2004 HS33’s on all my unicycles except the 36er which has a Magura frankenbrake.
These are $100/per wheel depending on which ones you want. They come with mounting instructions and are set up with black brake pads and whatever line length you want and a longer 10" crossover tube to clear wide tires (I can calculate line length for you if you want me to), bled and tested for leaks and function. Mounts not included.
This brake will fit on any Kris Holm unicycle: 20, 24, 29 and 36 or any brand of unicycle (Hunter, Nimbus, etc) that comes with dedicated four-bolt Magura mounts that look like this: http://www.trialtech.co.uk/images/L_TT_Sport_Fork_HS33mounts.jpg
You will need Magura four bolt mounts like this (I have a few sets of these too): http://www.trials-uk.co.uk/files/ecomproducts-image-1804.jpg
You will also need a place to mount your brake lever under the saddle like this: http://www.krisholm.com/khu/brackets
PAYMENT AND SHIPPING:
Paypal works best for me, but money orders are also ok. My paypal address is: uniflasher@hotmail.com. Shipping will be $5 for USPS Priority Mail shipping in the US (2-3 days) and $10 for first class shipping to Canada (7-9 days). I ship the day after I receive funds.
BLEEDING / TESTING:
I flush and bleed all brakes with fresh Magura blue blood before I test, pack and ship your brake. Bleeding hydraulic brakes is messy and no fun - and so you won’t have to deal with fluid leaks, after I assemble and bleed them with fresh Magura blue blood, I test them all for leaks by putting the wheel cylinders into a custom test jig that I made. There, I’ll cycle the brake pistons under full power to check for proper function and leaks without having to bolt them up to a unicycle frame.
MORE BRAKES AND PARTS:
E-mail me if you want something different or digital pictures of something in particular. I also have a good selection of less expensive nice used HS33 and HS22 brakes and several of my HS33/HS22 hybrid “franken-brakes” for 36” wheels too.
BTW, I also have these available separately:
- New Magura four bolt mounts with stainless hardware are $20/per wheel
- Magura rim brake bleed kits are $22
Cheers,
Brycer1968
503-358-2252
