It dawned on me while riding my new kh 36er on the trail the other day, that the exposed second hole in the each dual-holed crank was getting sprayed with water, mud and everything else!
The other danger is if the uni falls on a sharp rock and hits that open crank hole it can destroy the threads as well. So I thought it would be a great idea if Kris could have some plastic protective caps made specifically for the dual-hole cranks.
I brought this up earlier today with Josh at UDC, and he liked the idea, and thinks rather than a “pop in” type cap, a plastic cap that would screw in by allan key would be best, and also be long enough to protect both sides of each hole.
Anyway, I really think the caps would be a great way to keep the otherwise exposed holes clean so that when you are ready to switch holes, there would be no mud, dirt, dust in there, or possible thread damage.
I also think that in addition to these caps being made, that they should be included with every pair of dual holed cranks at no extra charge, just like crank axle hole caps or bar end caps, etc. I will expect my percentage once they are being produced, haha!
In the meantime, I’m using a small piece of duct tape, which seems to hold well in wet weather, but needs changing each time. The other option would be to use something like the expanding earplug-type foam, (cylindrical in shape) and compress it enough to get it into the holes, then let it expand. that should also work.
