Up for sale is my EXCELLENT condition KH 24" Muni, bought in 2009, Including adjustable rail mount for saddle with brake mount option! Thompson seatpost available +$50 Tire in Perfect condition hardly ridden at all. I had a 20" that I did all my riding on at the time. This unicycle will come to you ready to go, just put your seat on it. I have extra bumpers available also if you need them for your saddle! Also included is an extra two bolt seatclamp by Kris Holm! Thats two seatposts and two seatclamps. I did all my riding with pvc armor covering the frame so it has no wear on the paint.
Price is $450 which includes everything listed.
Payment by paypal verified account.
Features:
Saddle: No saddle included
Seat post: KH Adjustable 27.2 x 350mm bolt on style, sand blast black, pinned and bonded rectangular mounting
bracket, 4 hole
Seat post clamp: aluminum KH Double Bolt, black
Frame: KH Signature Blue 24" 7005 aluminum. Machined bearings, butted seatpost tube, and Magura brake mounts
Hub/axle: KH Moment ISIS, 36 hole, Aluminum, 100 mm center bearing to center bearing
Spokes: 14G. stainless Black (231mm in length for 3X)
Rim: KH 24", 36 hole, 47 mm wide, eyelets, offset spokes, ovalised holes, ERD 496
Rim strip: Blue vinyl
Tube size: 24" x 2.7 - 3.0
Tire: Duro Wildlife Leopard 24" x 3.0"
Crank arms: KH Moment ISIS, 150 mm, polished aluminum
Pedals: Animal Hamilton Pedals with Replaceable set screw pins, non-sealed, 9/16 threads
Bearings: 22mm x 42mm
Approx. cycle weight: 12.01 lbs.
Additional Information
Manufacturer Kris Holm
Brand-Unicycle Muni Series
Wheel Size 24 inch
Minimum Inseam Length 29" (74cm)
Type - Unicycle Mountain
Type - Seatpost Clamp Double Bolt - 27.2mm
Seatpost - Diameter 27.2mm
Color - Frame Blue
Color - Rim Anodized Black
Type - Crank ISIS
Crank Length 150mm
Type - Pedal Aluminum
Bearing Size 22x42x12mm
Cycle Weight 12 lbs.
