I was thinking about getting http://www.unicycle.com/unicycles/giraffes-tall/nimbus-performer-series-convertible-giraffe-unicycle.html, but on unicycle.com they say the minimum inseam length is 32".
I was wondering if anyone on here has used it and if that measurement is correct.
i suspect that figure will be accurate.
On the other hand if you cut down the tube above the bottom bracket correctly you could make it small enough for a toddler to ride…
There are ways though…
Each section is 400mm long. You can get a 200mm section and use that as the top section. That will give you a saddle potentially 8" lower!
Keep in mind that in unicycling, the inseam measurement is to the ground, not your ankle. (I think a regular 32" trouser inseam requirment would put a lot of people out of the running.)
Also note that rogeratunicycledotcom isn’t just a guy with a really long username, he’s Roger Davies, and I’m pretty sure he designed that unicycle. In other words, he knows what he’s talking about.
How would I go about ordering it with a 200mm section?
I dont think you can order it pre-changed so you will have a spare 2ft piece. Add some extra chain and you have the makings of a 9ft giraffe :P.
Tiney, contact them and ask. Sometimes they’ll make substitutions. The worst they might do is say no.
I think I may just order it seperately and have some extra length if I want to go taller. Thank you, everyone, for all the helpfull information.
