I could definitely see it, on one of those custom unis with wide square tread tires that are like 2 feet wide. Just ride, then go to hopping in seat drag, then step up onto the tire and start walking. That’s how I’d do it at least, someone who could both walk on wheels (like in the circus, not the unicycling trick) and ride a uni could probably do it easy, with the right unicycle at least.
I’d say it’s definitely possible. Difficult, sure, but very possible. Have you guys ever seen those guys that walk on barrels or logs that are rolling in water? I can’t see why you couldn’t do the same thing with a unicycle tire. It would be way easier if you had special tread custom made, though.
i think this is way different. i can balance on a floating log for pretty long, i even once walked all the way down a 50 ft log to another shoreline at a lake.
but i doubt i could walk on a tire.
That is exactly what I was thinking of, I was too lazy to look up the picture though. Idk if it’s even possible to walk on just a normal bike/uni wheel…
