Hey Setonix, regarding idling and riding. I actually “idle” more than ride. Every morning before work I get on it for 15 minutes. There is a parking lot with a nice culdesac. Just pop my trunk, change shoes and practice the following, “only”
a.) free mount: I do a method called “back mount”, which is from SIF → mount. which is stand behind unicycle, hands on seat, one foot down on pedal at 6 o’clock.. Then slowly rise up/over/down onto the seat. Immediately, get into idle. My goal is to rise and do the “perfect” pause at the top.
b.) idle: just “one rotation” frwd and “one rotation” backwards. That doesn’t sound like much but during the pedals at 3 & 9 o’clock I almost hold a standstill. The key to smooth idling is not quickly dropping into one foot down, but that transition part. BAlance, balance. Also, to condition your mind to be able to pause, and with lightning quick impulse “quickly decide/prepare body” to either rotate frwd or backwards. If I haven’t practiced enough, my mind quickly “glitches” or “goes blank”. Something you don’t worry about when you continually ride forwards and back. So, yeah…a lot of “mental activity” can happen just in the space of 3 ft in front and 3 ft behind you.
c.) Transition from idle back or fwd to “standing”
d.) Transition from idle back to SIF. Then sit down again. Now, this is a real workout. Switching back and forth can quickly cause fatigue in less than 5 minutes.
Anyways, that’s all I do everyday except on weekends I will go ride a little bit but mostly “slowly” on uneven grass or my favorite slow uphills. I guess you can call me more of an “idler” than a “rider”.
Anyways, for my friend Trivial out there. It seems you are fairly familiar with free mounting and idling. My first advice without getting technical is this:
a.) Just free mount and then “focus” on idling.
b.) Do not focus on getting up and “riding” forwards.
When I was learning there was always two big decisions. Should I go ride and “have fun” with this magical ability to balance and ride? Or, should I “waste time” and get tired from mindless boring free mounting? Yeah…that’s what I felt in the beginning. Forget about doing anything static. I want to go ride.
So, know my main enjoyment comes from achieving that perfect “static” balance positions, rocking back/forth, and then "getting off the seat and just holding it with my hands. SIF.
…slam
