You want to be the second fastest road unicyclist? Then this is for you.
A 32" version of the big #Flansberrium 36" V-frame. I thought I’d build a 32" and get a cool road uni, I just like muni too much and I barely use it.
The specs:
-Fits up to a 32" wheel.
-100mm wide hub, (Schlumpf compatible)
-Disk brake mount on the right (to use with outboard disk)
-27.2mm seatpost/31.8mm clamp
-28.6mm steertube, meaning you can use any standard bike stem for the handlebar setup. (Tube included)
-37.5° angle between front and rear frame.
-375mm clamp to clamp distance.
-Bottle Cage holes on the top tube.
This frame has probably about 200km on it. I rode it with my 29" geared wheel and it was a blast. It needs a better home though!
I could add a disk mount on the left for extra cost before shipping.
Asking 700$ CAD OBO, I can ship anywhere, buyer pays shipping. Located in Quebec Canada.
Some pictures on the 36" version here. Last year, I broke the 10k race world record with this unicycle (before mounting Martin and Roger’s adapter and the carbon rim). If someone wants to build a G32 with a disc brake on the hub (like my G36), a brake pad needs to be installed on the left side.
Yep, and Jacob said he can do it before shipping the frame:
This uni is such a beast from another world… I wonder if you get any “where is your other wheel?” with it. Or probably they don’t have the time because you’re so fast!
I do not have pictures with my setup unfortunatly, but the frame is the same angles as @toutestbon setup. The difference is his is a 36" and the one for sale fits a 32" wheel.
As said in the post, I can add a disk brake tab (or anything else!) before it’s sent!
How well do you think this would work for touring? I’m thinking full-on uni packing, with a tent and gear, a la Ed Pratt. Seems like it would have room for a decent amount of gear between the seat and bars, but I can’t really picture how knee clearance is going to work with that geometry.
I’m sure you could add a brace across the top of this area and build a custom frame bag to fit, just like a bikepacking setup.
I’m sure you would be OK with the width of the skinny part of the seat or a bit more, so no bulky items there, but it would be a great spot for heavier items if you can make it work.
Like anything else custom I think you would need to prototype and experiment to find the right setup for you. If you do buy this and build a unipacking setup please share pictures!
I just had another thought, a small triangle bag between both the frame crowns and the seat base, then a custom prism bag from the seat front, the front crown and the two close wide handlebar ends. The possibilities are endless.
It has holes on the top tube for a bottle cage, so if you get a bag made for that it could have holes so you can bolt it in to secure it too. I think you could put stuff that needs to be accessed fast in that part!
