Hello all-
I am developing an epicyclic hub gear for unicycles. This is a topic that has been beaten into the ground in the past along with wheel size for an ideal big wheel so grit your teeth (good engineering pun, that) and I will explain my motivation, describe the plan and schedule, and ask for input. Keep in mind that a geared unicycle can only compete with a high end, pneumatic tired big wheel in the catagories of speed and weight. A big wheel has an esthetic appeal unattainable by a “standard” sized unicycle (I don’t know about you but that is why I bought a Coker) as well as enhanced ride comfort due to the wheel diameter and associated angular momentum. There is also the belief that big wheels are more easily controlled than geared unicycles, but that may be a problem due to backlash in geared systems more than anything else.
Several threads have already dealt with geared unicycles. It seems that geared giraffes, chain driven standard unicycles, modified Sturmey-Archer (S-A) hubs, and external gearing have been tried or seen by others. I don’t think anyone has designed and built an epicyclic hub gear strictly for unicycles. This would necessarily differ from the S-A hub in that the crank axle, or applied drive shaft, must be the inner most rotating shaft. In the S-A, the drive is applied to a chain sprocket which is inside the fork and is the middle rotating shaft. The difficulties encountered with modified S-A hubs, as I understand it, are hokiness, backlash, and lack of strength and reliability. After all, they were designed to be freewheeling (infinite backlash) and chain driven.
Chain driven attempts all have to deal with the problem of chain stretch and slackness and its associated backlash. Uniformly driving both sides of the hub seems to be a problem also. These are difficulties that will always be encountered in giraffe designs as well as chain driven geared unicycles.
Externally geared unicycles all seem to require split crank axles. This has to be a serious mechanical weakness and I would think that the fork is the part that has to be reinforced to accommodate the design.
A properly designed epicyclic hub gear for a unicycle should have a continuous (unsplit) crank axle 17mm or so in diameter. It should have very small backlash. The gear ratio limits for simple sun/planet/ring systems vary from 1 to 2 with realistic (attainable) ratios from 1.2 to about 1.8 or so. Compound gear systems can produce much higher ratios with a cost of increased weight, volume, and complexity. It should use off-the-shelf, standard gears, retainers, and bearings.
My prototype design will have (or has) a simple gear ratio of either 1.5:1 or 1.625:1, an aluminum hub with a flange diameter of 3.75" (big), a continuous 17mm crank axle, standard steel gears, standard, sealed ball bearings, and is servicable by removable caps on each end of the hub. The backlash should be 4 mrad or 0.23 degrees which is about 0.024" or 0.6mm measured at the pedal on a 6" crank.
The ratio of 1.5:1 is highly desirable because it makes a 24" wheel into a 36" wheel equivalent. There are many people who have experience riding on a 36" wheel with 6" cranks and could therefore make an accurate comparison. I live in Seattle and my goal is to build at least one prototype to have available for people to try at the 2002 NUC and UNICON 11 in North Bend, WA next year. Hopefully, lots of people who ride Cokers will show up and test it so I can determine the control weaknesses. Hopefully there will be riders there strong enough to break it so I can determine the mechanical weaknesses too.
A gear ratio of 1.625:1 will make a 700c wheel (which is a standard mountain bike size about 27" in diameter) into a 44" wheel equivalent behemoth. There are lots of different 700c wheels and tires. This design can probably be easily altered to make a hub that can be shifted to direct drive (1:1) so, if it is rugged enough, it could be shifted to high gear to cruise to an offroad trail and 1:1 to go trail riding.
Any feedback would be appreciated. If anyone has (supportable) arguments against an initial gear ratio of 1.5:1, let me know. If anyone wants to donate time or parts to this project (lace a wheel, provide a fork, provide a variety of seatpost lengths with seats, etc.), please let me know. I have a rough AutoCAD drawing of the stackup of my third design pass. I will probably make two more drafts before I start machining.
Thanks.
