Last year I had the pleasure of trying to install a Coker tire on an Airfoil rim. I had a very difficult time trying to get the tire on the rim. I had such a difficult time that I wrote a thread about it: Putting a Coker tire on the Airfoil rim.
When I got home from NAUCC this year I had the pleasure again of installing a new Coker tire on the Airfoil rim. This time it went much easier.
At the beginning of the 10K at NAUCC I noticed that I had about a 1/2" cut in the tread of my Coker tire. The cut was in the center area of the tread. Fortunately it wasn’t on the sidewall, and fortunately it didn’t go all the way through the casing. But it was clearly a bad cut and I was going to have to replace the tire. Bummer. The tire still has lots of tread left.
This time the tire change was much easier. The trick was switching to a different rim tape. Last time I used Velox rim tape. The Velox rim tape is good stuff, but it’s rather thick and not very slippery. The thickness makes it more difficult to install the tire. The lack of slipperiness makes it more difficult to get the tire to slide all the way into the center lowest part of the rim channel during the tire install.
This time I tried Rox Ultralight Rim Strip. This rim strip is very thin and very slippery. I’m not sure it would do well in a super high pressure road bike tire (120 psi to 160 psi), but for the Coker tire the Rox rim strip should have enough substance to keep the tube away from the nipples and spokes. A single roll contains two rim strips which is enough to do two bicycle wheels or one Coker wheel.
The Rox Ultralight Rim Strip made the Coker tire install sooooo easy. I did the tire install using two Quik-Stik tire levers and a bicycle toe strap. I used the toe strap as a third pair of hands to hold the tire in the center part of the rim channel while I used the tire levers on the opposite side of the wheel. Easy. The Rox rim strip allowed the tire to easily slide all the way into the center area of the rim channel (where the diameter of the rim is the smallest). The toe strap held it there. Prying the rest of the tire over the rim was easy. I think I could have actually pried the rest of the tire over the rim without any tire lever tools at all if I had to. Wow!
The big trick is the Rox Ultralight Rim Strip. U-Turn has been using Salsa rim tape, but I couldn’t find the Salsa tape at any local bike shops. I was able to find the Rox rim strip. I haven’t tried the Salsa tape so I don’t know how well it works and how easy the tire install would be. The Salsa rim tape is thicker than the Rox Ultralight rim strip so I would expect the tire install using the Rox Ultralight rim strip to be easier.
No longer am I scared of repairing a Coker flat out on the road. I know I could do it if I have to.
Rox Ultralight Rim Strips rock!
