Dumb Mistakes
Post yours Here…
Let me start.
Always Tuck Your Laces!!
I know better and was too lazy to do it this time.
The laces wrapped around the petal shaft and ripped two eyelets out of my sneakers.
It makes it difficult to bail if your Uni is tied to your shoe!!
Thankfully I was going slow and was able to step off with the other foot.
Nothing hurt but my pride.
Learning to ride a unicycle. What. Too specific? Should I step back even further? Being born would seem to be a qualifying event… :stuck_out_tongue:
I was not so lucky. I had had it happen to me before, and observed it happening a lot at uni conventions. Here comes little Jimmy along the back side of the track. He’s doing well! Then, for no apparent reason, he does an instant faceplant. His shoelace got loose…
I’d experienced it enough times that I had developed a reflex for that situation. If you’re not going real fast, stop. If you’re going too fast to stop within a rotation or two, pedal as hard as you can! It happened to me while trying to see how fast I could go on my Coker with 150mm cranks. I think I got up to about 15mph down the little hill, and was slowing a bit when I felt that familiar tightening. No real choice when going fast on a Coker; FULL POWER! Didn’t work. Ow. My shoelace did finally break before the crash was over, taking two eyelets out of my shoe. But I busted my clavicle and got some nasty road rash. And I had to miss the 2007 California Mountain Unicycle Weekend, which started a few days later. :frowning:
Since then, I NEVER ride with out first double-knotting my shoes. It’s always a pain at the end of the day, but it’s worth it!
Attention startup company entrepreneurs…
When needed, hospitals and nursing homes prescribe pediatric shoes which use Velcro straps to hold them on patients’ feet. But these typically are quite boring to look at, colored black or hospital white. And so what is needed is a much livelier appearance, suitable for spectacular unicycling. No laces required!
I absentmindedly put my seat on backwards on my 36er and, after about 7 miles of riding, my left pedal fell off because the crank arm was stripped and ruined. It was a long walk home.
I just don’t tighten my laces too much. That way I can just step in and out of my shoes without ever having to untie them. Also keeping the laces short in case they do come loose, will not get them entangled around the pedals.
There are many MTB shoes available with Velcro straps :slight_smile:
Ever since starting this insane hobby almost two years ago I’ve been tucking in my laces, a shoelace trip-up is my worst fear in unicycling.
Just last Sunday: not slowing down before a rear-dismount on a somewhat slippery surface.
Result: my 2nd real backward fall in almost 2 years.
As I had my tire on road riding pressure it made a nice triple skid mark though :slight_smile:
The other one happening on my 3rd day of unicycling
I had this happen yesterday evening – luckily it was on my 20" and it didn’t damage my shoe (or me). It is actually the second time in as many weeks, albeit with different shoes.
To be fair, yesterday was a bit opportunistic, the uni was in the back of the car, the sun was shining and I had five minutes, so I just jumped on it without too much thought about tangling my feet up. The dismount involved stepping over the wheel with my free foot, which could be the basis of something quite cool, but certainly above my present competence level…
I think that this problem is made worse by having the pedals in the inside hole of 125/137 cranks so that the end of the crank is spinning round looking for something (like the bow of a shoelace!) to hook into…
Laces
5-10 BMX shoes have a tongue that covers the laces and Velcro’s down
Always tucked my laces in until one day I thought , “nah it’s probably not that important”. Riding my 20” up to a crossing… hop, skip, trip… drag unicycle behind leg as foot is now tied to the crank shaft. From now on always tuck in your laces.
[quote=johnfoss;1704615.
while trying to see how fast I could go on my Coker with 150mm cranks. I think I got up to about 15mph down the little hill, and was slowing a bit when I felt that familiar tightening. No real choice when going fast on a Coker; FULL POWER! Didn’t work. Ow. My shoelace did finally break before the crash was over, taking two eyelets out of my shoe. But I busted my clavicle and got some nasty road rash. And I had to miss the 2007 California Mountain Unicycle Weekend, which started a few days later. :([/quote]
Wow…Go Big or stay at Home!! :astonished:
Note to self…
I have had one good one (4th day riding) and did a number on both elbows.
The bow is what wrapped on mine.
Sebcycle…For some reason the system will not let me quote you.
My visual image of you dragging your uni is priceless!:smiley:
Sorry for the individual quotes. I can’t seem to get the multi-quote to work.
I once loaned someone my 26” muni. As I was about 10” shorter than them I changed the seat post for a longer one so it would fit them. A while later I got my unicycle back but forgot to alter the seat post. Fast forward to me taking my unicycle out for a ride, and the seat was too high for me. If I lowered it enough be able to barely sit on it the post went all the way down and caught on the wheel. Doh !
First time attempting to ride across the Forth Road Bridge. So busy worrying about what the weather would be like that I forgot to pack the pedals !
It doesn’t work that way if you’re going fast. If you’re going really slow, it’s not much of an issue. Keeping the laces short is a very good idea, however this will not prevent them from possibly coming lose.
As mentioned earlier, some models of 5/10 MTB shoes (not just BMX variants) have a velcro flap that goes over the laces. Those are the ones I use, though I forget the model name.
Really. I ended up staying home from Muni Weekend, but this was mainly because I would have had to miss the last day anyway; we had a pre-planned trip to Cancun. I took some great pictures of the Chichen Itza pyramid, but every time I had to turn my camera to portrait mode, I had to push up the camera with my left hand, while my right held the lens and shutter button. Ouch!
Anybody know if that’s peculiar to 5.10? I’m on my second such pair, and the flap is just the ticket. The laces do get out on rare occasion, although that’s impossible, so I keep them short.
