I have looked at that rotor before and it looks pretty good- although could it be a bit too wide to work the the KH Spirit mount system?
I’d love to upgrade to discs and I will eventually but it is a big cost to upgrade from maguras. I’d prefer to get a new KH frame with the welded disc mount because it looks better and so you don’t have to take the bearing holder with the brake off everytime you take your wheel out of the frame! Also the D mount would require a lot of machining which could be costly.
So heres what I’m thinking I’ll do when I upgrade to discs for the 26 all mountain + downhill rig.
New KH frame with welded frame mount -$240 (sell my current kh26’’ frame)
Spirit cranks 150/127 - $170 does any one know why it says 160 mm or 180 mm disc here http://www.krisholm.com/khu/spirit I get why you can’t have a 160mm disc but why not a 203mm disc?)
Then for a brake I was thinking
http://www.chainreactioncycles.com/Models.aspx?ModelID=82434 Shimano Zee Disc Brake M640 $224
http://www.chainreactioncycles.com/Models.aspx?ModelID=54868 $220 Shimano XTR Race M985 Disc Brake
http://www.chainreactioncycles.com/Models.aspx?ModelID=83173 Shimano SLX M675 Disc Brake looks like a great cheaper option @ $146
http://www.chainreactioncycles.com/Models.aspx?ModelID=73474 Hope Tech X2 Evo Front Brake cheaper than I though hope brake would be, I really like how you can get it fitted with braided hose at $210 love the hope machining too.
All those brakes have good reviews and pretty good weights. I want to get a reliable brake and one that can take a bit of a beating.
For a rotor I’m not sure weither to get 160/180 or 203- I’d prefer to have a smaller rotor thats more out of the way with more modulation just as long as it have enough heat distribution and power. Shimano XT/Saint RT86 Ice-Tech 6-Bolt Disc Rotor looks good but seems kinda pricey for $50 a rotor
Or maybe a hope floating rotor.
Or this one is even cheaper just looks like an older model for about $40 http://www.chainreactioncycles.com/Models.aspx?ModelID=39007
Or Avid HS1 Heat-Shedding 140/160/180/200mm Rotor for $50
And finally a KH Starfighter Brake Lever Extension for $40
Far out so with new frame + new spirit cranks + hope brake + rotor+ starfighter it comes to a wooping $700! - say minus $160 for selling my current KH frame, so about $540 Eeeeek thats an expensive upgrade haha- might not happen for a while
Any thoughts on my plan and what brake do you think looks best?
