Hi, I am wondering what size crank I might want since I am getting a new unicycle soon. At the momentvi am using a home made unicycle with bike cranks that are like 200 mm. The pedals touch the ground when I turn sometimes. So I obviously am going to get ones that are shorter than that. But as I have only ridden one unicycle I’m not sure what’s best. I am going to ride some trials and flatland. I would just like to know what some people would recomend.
Just so you know most bike cranks are 170-175mm You measure from the center of the axle hole to the center of the spindle hole. Not the whole length of the crank.
To be honest, I’m not sure about 137s either. I still hit the ground with 125s on my 20" and wouldn’t recommend anything longer than them (125s) for regular riding.
you must be doing some sharp, sharp turns then, because i have both 125’s and 137’s, and the 137s rarely, if ever, hit the ground. all i do is trials though.
I am looking at municycle.ca. And it’s an upgrade on the nimbus trials and it only shows as low as 137mm unless you get double hole. But thanks anyway.
So, to the point, you guys recomend that I get short cranks? Like, 110mm Or 125mm if I can?
Indeed you can’t select the 125mm moments here but since the description says “Available in lengths of 110, 125, 137, 150 and 165mm” you should just ask them at unicycle.com. Maybe 125mm cranks are out of stock just for now.
Regarding length I would recommend 137mm cranks anyway. You will be able to learn all flat tricks with that length but you have more control for trials.
That’s interesting. I stopped using 125s (for Freestyle) because the pedals hit the ground way too much. The Schwinn 20" used to come with 140s! I used one of those at Unicon I to win the Pairs competition. Just goes to show how important it is to know what riding style the person is talking about…
