I know there are already plenty of threads about cokers, but I thought if we have a Muni discussion thread, and a trials discussion thread, then we might as well have a Coker discussion thread.
Lol.
ok Iāll start. my radial 36er deluxe ROCKS! Ohā¦it can be ANY 36er, or only ācoker?ā ![]()
any 36
although i personally have a coker (as you know
haha
but yes, all welcome
Well I have two 36ers and a Muniā¦so those are sexy measurementsā¦36 24 36! ![]()
Do modded cokers count??? ![]()
I donāt see why not.
Sweeeeet!!! cause mine had a Low Profile 40" tyre on it and magnesium pedals on 102s.
[U]For those that donāt know.[/U] ![]()
Low profile means: An upgrade to a tyre with a lower profile size than the original will generally improve the vehicleās steering response, handling characteristics and appearance. There are options of changing the rim width and diameter, which will maintain similar specifications to the original tyre fitment.
My 36er
Nimbus 36 Deluxe
Airfoil rim (small one:( )
TA tire, soon to be grooved and studded
stainless spokes
UDC superwide hub, thiking of switching to a āregularā wide hub or eventually a schlumpf if I save enough money.
T7 bar with drops, very similar to this and a little stubby thing with a light taped to it.
KH freeride saddle
170mm cranks (winter mode)
DX pinned pedlals, might switch to snafus
blinky red light in the back
bike saddle bag on back part of frame
water bottle cage held on with hose clamp because the mount thingy broke
lots of 3M reflective tape on the frame and rim
bike computer with a mini-audio plug thing spliced in the wire so I can take the handle off without completely removing the computer or cutting the wire.
Very fun machine and my main mode of transportation since my truck got schmucked.
Hey Hazmat: I have heard you talk about you moded coker many a time. did you extend the fame to fit your bigger wheel? I know a 40 would not fit in my nimbus frame.
The wheel was 40" tall right, not just a bigger rim with a low profile tire and still 36" tall?
Iāve ridden a coker once or twice, it was pretty cool.
But riding a 20" schlumpf beats the hell out of any coker.
'07 Radial frame 25.4mm
Custom Powder coat blue
qu-ax 114mm alum cranks 0-Q
Airfoil rim (no issues at 40 psi)
TA tire
UDC wide hub
KH fusion freeride saddle
Quick realease seatpost clamp
KH 25.4 seat post w/rail addaper
T7
āairzoundā re-fillable airhorn (120db max)
(Also secondary KH fusion freeride saddle and seatpost [minus T7] for ācoker muniā)
Nimbus 36
Airfoil rim
TA tyre
UDC extra wide hub
DMR magnesium pedals
KH fusion freeride seat
KH seatpost with rail adapter
T7 handle
Mine is a QU-AX 36". So far, only muni seat and flames valve cap are custom. Iām thinking of buying a freeride seat someday.
pdc, your seat is angled up quite a bit!
Still waiting for picture too.
At least just spend a few dollars and get a disposable camera and get some pictures with that.
I donāt know why people want pics of it???
All you have to do is picture a coker with a slightly larger tyre and thatās it. ![]()
So, how do cokers respond to snow and ice? Specifically, the TA tires?
Oh, thanks
