i have ridden a "12 wheel without a long seatpost.
(i rode the "12 trainer)
it was hard to ride anyway but even during the slightest turn the pedals would hit the floor! it wasnt hard to get the hang of but i wudnt suggest it unless u were performing for an audience as you cant realy have fun with it otherwise!
Yes, you forgot to say what you were going to use it for. I have a 12" uni (Unicycle Factory), but it’s just for shows. It gets great audience response though; the lower the seat, the better!
For any other use, you will find a 12" a pain to ride. The pedals will almost be hitting the ground when you ride straight, let alone making turns.
Eve if it’s for a small child, go for a 16" unless you absolutely know the child is too small.
If you’re a professional performer and intend to use it for shows long-term, save your money for the sturdier one.
Radial spoking bad… Both seem to have it. I know the trainer does. The dodger might have a cross in there but I dont know.
I rode the trainer the radial spoking makes it hard to ride because of the lag time between the cranks/hub to the rim. It also wears out fast. Idling I’m sure puts stress on it.
I have a 12"! its kind of fun for about 5 minutes. I got it from evan for my little sister who is almost 3 but she is still too small. I rode it around with the seat touching the frame (as low as it could go) and my neighbors laughed at me.
