Worth trying to save an early-2000s Onza splined hub + cranks?
Is there anything particularly special (apart from the hedgehog logo!) about an early (pre-KH) splined Onza unicycle hub that would make it worth me trying to fix/save it?
I have started working on a twin-tube-forked trials unicycle from that era that I have acquired, and I was initially thinking I would try to restore it with all its original parts, including this hub and cranks (which would have been top of the line in their day I believe). They certainly are unusual in their construction (loose fitting 6004rs 42mm bearings, any number of spacers, strange fitting of hub body to axle, self-extracting cranks,…), and are definitely a piece of history, but I’m coming up with more reasons to swap them out than keep them in.
I already knew they had proprietary 140mm cranks, so no swapping for a shorter length, but I was going to live with that. However now I see that the cranks have a large Q-factor, and the hub seems to have some noisy internal play, which may or may not be possible to repair. And then to cap it all (sorry) the uni frame has 40mm bearing housings, so the hub’s 42mm bearings have just been squashed into them with very few points of contact.
So now I’m thinking that unless this hub is some real classic that I’m lucky to have got my hands on, I’ll just swap it out for a chromoly cotterless hub with 40mm bearings so I can run some shorter cranks and not have creaks.
It seems fitting to try to get said hub from an old uni of the same sort of age, but have their been any strength improvements with newer newer chromoly hubs that would make it worth buying new(er)? Despite this being a ‘trials/street’ uni by design and previous use, I think my use of it won’t trouble a strong cotterless hub and cranks too much.
Here’s the whole uni before I started - it may get its own separate thread in due course.
The top of the frame is making a weird bend in the picture (maybe the camera angle) :thinking:
Technically speaking, you could fit any tubular Onza or KH/Onza on it and there should be down to 125mm (if you can get your hands on some). Otherwise, it is cut-and-weld (at least one forum member did so on Profile tubular cranks).
If you feel like going the swapping route (and the 42mm bearings do not have an unusual internal diameter), I can pay shipping to store it in my garage until I decide to build a hedgehog wheel :yum:
I agree it’s weird, but as far as I can tell it’s by design, there’s no indication of any bending or compression. The front and back tubes of the fork are of noticeably different lengths, then the braising at the crown is off-straight.
Re shorter Onza cranks, if I find the hub play isn’t troublesome (I have a Schlumpf on another uni so I’ve got used to some play!) I’ll ask around, but elsewhere on the forum I’ve read those 127mm ones are like hen’s teeth. @JimT has shortened some Profile cranks, but I don’t have those skills. If other things fail you have first dibs on the hedgehog, although I’m growing fond of it!
