I just did that last weekend, and they were very bad. I could barely rotate the
bearings with my hand. When you change them, make sure you put in bearings that
are sealed on both sides. The ones that were on mine were open on the one side
making it where lots of dirt and gunk could get in and destroy the bearing.
Kevin Gilbertson <mail@gilby.com> wrote: :> Change the bearings on my Coker…
: I just did that last weekend, and they were very bad. I could barely rotate : the bearings with my hand. When you change them, make sure you put in bearings : that are sealed on both sides. The ones that were on mine were open on the one : side making it where lots of dirt and gunk could get in and destroy the : bearing.
Well I’ve done it, not too hard a job, with as roger would say " the right
tools" I used a DM puller and it was quite easy to get the old ones off. They
were in dreadfull nick. One had shattered the outer ring, in the bearing
holder, its scored three groves into the holder. Fortunatly there was enough
left of the outer ring to get the puller around. The other one had a crumbling
shield so there were bits of the shield in with the ball bearings. My new
Bearings are sealed, hopefully they will last longer than the 100 miles I got
out of the last set.
I also put some 5 inch cranks on the wheel to try them out for size, even in
the short trip to work I could tell they were speedier. BUT the up hills were
harder and crosing a steep camber from the pavement caused problems when the
wheel got stuck
_______ HERE ______________ l___—
and I didn’t have the leverage to get it to roll out forwards. I suspect that I
will return to 6 inch cranks before too long, I’m not that good up hills.
> > Change the bearings on my Coker… > > I just did that last weekend, and they were very bad. I could barely rotate > the bearings with my hand. When you change them, make sure you put in bearings > that are sealed on both sides. The ones that were on mine were open on the one > side making it where lots of dirt and gunk could get in and destroy the > bearing.
The secret is having the correct tools… DM manufactures a special tool for
extraction of unicycle bearings. It is fantastic and enclosed the bearing
totally and pulls evenly. The other thing to use is a 3 leg bearing puller, but
the problem is getting one small enough for the 40mm bearings.
Cheers
Roger
The UK's Unicycle Source <a href="http://www.unicycle.uk.com/">http://www.unicycle.uk.com/</a>
----- Original Message ----- From: Kevin Gilbertson <mail@gilby.com> To:
<unicycling@winternet.com> Sent: Friday, March 03, 2000 11:13 AM Subject: Re:
wish me luck…
> > Change the bearings on my Coker… > > I just did that last weekend, and they were very bad. I could barely rotate > the bearings with my hand. When you change them, make sure you put in bearings > that are sealed on both sides. The ones that were on mine were open on the one > side making it where lots of dirt and gunk could get in and destroy the > bearing. > > Good luck! > ----------------------------------- > Kevin Gilbertson - mail@gilby.com > IT-Labs: gilb0179@itlabs.umn.edu > http://www.gilby.com/ > -----------------------------------
