I was just checking weights on unicycle.co.uk and after looking weights for most of the heavy parts I found that the 19" nimbus ISIS trials should be slightly lighter than the KH street uni.
KH frame is 200-300 grams lighter but Nimbus cranks are 200-300 grams lighter.
Nimbus hub is slightly lighter, nimbus rim is slightly lighter, so why is the Nimbus 5.7Kg and the KH 5.5? I know 200 grams isn’t much but I’m just really interested to know what’s so heavy on the nimbus apart from the frame?
Hmm, I couldn’t get weights for the seats but they are basically the same aren’t they? KH seatpost is like 50 grams lighter, so maybe it is the seat? I have a KH seat on my nimbus anyway.
Maybe some day I’ll upgrade my frame and seat post to KH, but it’s only a 300-400 gram weight loss.
I need to accurately weigh my uni some time, I just don’t have scales.
i just bought a nimbus with moments and i noticed that theres not much difference between it and the kh. I assume because the seat post is thinner, along with the frame.
I do need to weigh mine though, I think I have the same set up at you, just not a CF base. I don’t have any scales accurate enough at home though, I think the wheel with no pedals would weigh less than 3KG so I’ll weigh the parts on the kitchen scales
O BTW, try standing on the scales, then hold the uni and take the difference. That’s more accurate for scales designed for heavier stuff.
When your next doing maintanence, or like changing the tyre or something and you have your uni in parts weigh them on a set of kitchen scales then add it all together.
The 42mm rim on the Nimbus will save some weight. Hell I took of 250g just by switching to Xpedo Mangnizium pedals. What tires does the Nimbus have? Tires make up a big percentage of the Uni weight. the guage of the spokes can also make a difference.
I would say that the biggest components by weight are:
Rim
Tire Including tube.
Saddle
Hub
Frame/Pedals/Cranks
Post/all spokes.
Seatpost Clamp.
Of course what brands and guages you use can change the order here somewhat.
Weights from UDC website
For the KH, the tire is the heaviest component followed saddle (guess), pedal, hub, crank, frame for the Nimbus the order is; tire, saddle, frame, hub, pedal.
Like Unicorn said, you can easily save some weight on the KH trials by swapping to lighter pedals.
