i just got back from a half hour ride on my fixie. finally took it out of winter storage (well, i bought it like last november. and i stopped riding it around new years since it was so warm here)
can’t do anything yet. can barely get my foot into the clips. turning scares me because my toes rub on the front wheel. and as much as i try to not use my brake, i have to on downhills because my leg muscles are pretty shot right now!
the only time i ever tried one was when my (super cycle athlete) single speed friend tried it out on his bike and hated it. i got on it and found it very instinctive. if i ever get a bike again, 'twill be a fixie
I bought a singlespeed / fixie a month ago. It has a flipflop hub on the back and can be flipped from singlespeed mode to fixie mode.
I’ve been riding it in singlespeed mode. I hope to be riding it more often in fixie mode, but I’m still getting things adjusted and sorted on the bike. Once I get it all sorted I’ll try the fixie mode more.
Current gearing is 46/18. That gearing works great for the mostly flat bike trail where I’ve been riding it. Gets to be a bugger on short steep hills though. First thing I checked when looking at the bike was if I’d have problems with toe overlap with the front wheel. The front of my shoes just clear the front wheel with millimeters to spare. And that’s with using 170mm cranks. It’s gonna be a good fit for fixie use.
I’ll have to see where all this goes and how much I’ll be liking the fixie option vs. the singlespeed option.
yea, bmxes is a singlespeed. but when most people talk about singlespeeds, as in piecing one together or racing them, they mean mountain bikes with only one gear…
Every time I mention to people that I have a fixed gear they always ask if it’s like a BMX. And all the BMX’s I know and/or have owned are always single speed. So either I’m not describing it right or a whole lot of people can’t tell the difference.
I think there is a small difference between BMX and MTB
BMX
BMX is an abbreviation for bicycle motocross, the style of biking created with its use. BMX biking is an started by kids trying to emulate their favorite motocross riders on their own bicycles. BMX bikes are traditionally set on 20’ wheels and smaller than normal frames. The ratio of the frame size allows riders to maintain controller when performing tricks. The handlebars on a BMX bike can spin completely in a circle. This in itself is considered a trick in BMX. BMX bikes are used to ride in streets, on half pipes, in dirt jumping and more.
MTB
A mountain bike, also called a dirt bike or trail bike, is designed exactly for its name. Mountain bikes are used to ride in mountain terrain: rocks, hills, dirt. Mountain bikes are known by their wide tires and handlebars that are perpendicular to the ground. Mountain bikes are also equipped with a shock absorption system, key when riding on rough ground.
A whole lotta people don’t know the difference. I have never seen a fixed gear BMX style bike. People obviously just don’t know what they’re talking about if they get them confused.
There’s a core group of older guys who ride fixie on the trail network at UMaine. I’ve only seen them a couple times, but they’re nuts. I’d like to give it a shot sometime, but don’t want to spend the money to build up a cheap bike now.
From what I can see, those are fixed gear bikes, because I don’t see any brake leavers on the handlebars. (Single-speed needs a brake, and always rear. Fixed gear either go no brakes, or a front brake if the rider so chooses)
They’re not coasting. They’re skidding. They do a damn good job of it though. Basically they lock the back wheel from not pedaling. But they lean so much forwards their back wheel isn’t touching the ground nearly as much so they can continue to move on their front wheel.
