I don’t want the KH, maybe because the brand just always is most expensive, but does that mean that KH also is better than the other brands. I like my KH’s, but mostly I ride the Nimbus 29". I see that the Nimbus trials are cheaper than Qu-Ax even.
I choose the long neck because I’m 1.86m (6’2"). So I already made my choice of what I;m gonna buy, but I am just interested to know if one brand is better than the other.
If you already have many Unicycles I would say go for the cheapest. I bought a brand new Nimbus only because it was the cheapest I could find back then (old model from a web retailer - not directly from UDC) and it does the job very well. I mainly use it to improve my hopping skill and learn some flatland tricks, etc..
Also don’t forget the ‘Indy’ Trials Unicycle option which is probably the cheapest choice, link below for spec:
I frequently use the terms 19" and 20" interchangeably. I think the outside tire dimensions for both the 20" freestyle and the 19" trials tire are the same. The 20" freestyle tire is typically a high-pressure/low-volume tire, while the trials is a low-pressure/high-volume tire. The relatively small contact patch of the freestyle tire helps to facilitate pivoting easily. Though I no experience with the narrower hubs and narrower Q factor of freestyle unicycles, they are reportedly better at doing things like pirouettes.
If you want to experience moderate speed, are afraid of face planting, and if you enjoy mixed road-off-road XC, then a 29" might be the wheel for you.
My first unicycle was an indy ‘freestyle’. I now consider it the base benchmark of things that can be wrong with a unicycle.
Here is my list of what I think of the components:
Saddle distinctly flexible and uncomfortable for a full grown rider and will need to be replaced for anything more than learning to ride. Due to having a non standard seatpost this needs to be replaced at the same time. The seatpost clamp MUST be replaced or you will curse it forever.
My frame was not properly aligned and required bending and filing when I replaced the hub.
Tyre and inner tube passable but rim single walled and low quality.
While nothing was wrong with the cranks and pedals, my hub was faulty and wore through 2 pairs of cranks before I replaced the uni.
After sitting unused for around 3 years, I built it back up with a spare Nimbus hub, Qu-Ax cranks and a passable flattened KH saddle experiment and sold it on for my sisters friend to learn on.
It is seriously worth spending the extra money for a Profi or a mid range Nimbus.
The Qu-Ax linked above looks excellent. I don’t have much first-hand experience with this brand, as it is not generally available in the US, but I do prefer a longneck frame, even though I am 10cm shorter than Setonix.
KH is good but overrated, and, in my experience, not worth the extra money. Nimbus is excellent.
