Where can I get some nice 114/100mm ISIS cranks in the US that won’t strip in 1 week. Also, is it possible to drill and re-tap KH cranks at a shorter length. If I lived in Europe I would get k1, but shipping would be insane to the US.
EDIT: This is for a KH 29er and 125’s are just too long to commute with.
Agreed. Qu-Ax cranks should not be stripping, especially if you are just commuting. I have been using the square taper version on my 36er for almost 2 years with no problems.
Get some new 100mm qu-ax cranks and make sure you put them on right and put your pedals on correctly. Make sure to tighten the crank bolts frequently when you first put the new cranks on because cranks tend to come loose when you first install them. You were probably riding with loose cranks, it is harder to tell that cranks are loose when riding ISIS.
Unfortunately as well, there aren’t any other options that I know of for lightweight ISIS cranks in small sizes.
I’ve had 114mm qu-ax freestyle cranks on my street uni for a month and I’ve been crankflipping and jumping three-sets and plenty more and they aren’t stripped, nor have they bent at all.
I don’t know whats wrong with you guys who strip them out and bend them so quickly. Maybe you are over tightening them? Bad form? Who knows? I have no idea but mine are holding up perfectly fine.
