Re: Wheel-Walking a Bicycle?
Text item:
>For those of you who can wheel walk a unicycle, have you ever tried sitting
>on the handlebars of your bicycle and wheel walking the front tire? Is it
>easier or harder?
Easier but different.
>I can’t do either, but I imagine that the bike would be less scary simply
>because you wouldn’t fall foward/backward. However, it is possible that the
>left/right turning would be more difficult, to the point where perhaps a
>unicycle would be easier. Any thoughts or experiences with this?
All you have to do is lean back slightly to keep some weight on the rear
wheel. You still need to be very aware of your balance because you’re going
real slow, and you still have to steer to stay balanced. If you turn the
wheel too much, the bike will fold over. Steering would not be difficult, but
the whole process is inherently awkward.
>Would a bike perhaps be a good stepping stone to learning on a uni?
It might be a good way to learn the foot action, but will not help you with
the balance. I would recommend getting comfortable rolling your feet down the
front of the tire one by one, smoothly and swiftly but without letting the
bike coast (that would only come much later on the unicycle).
When your feet are used to pushing the tire without knocking each other off,
it’s time to go back to the unicycle hold onto a wall (fence, or someone
else’s car).
John Foss unifoss@calweb.com
Text item: External Message Header
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: juggler@deltanet.com (JAG) Precedence: bulk Sender:
owner-unicycling@winternet.com Xref: paladin.american.edu
rec.sport.unicycling:5109 X-Newsreader: Forte Agent 1.5/32.451
Content-Transfer-Encoding: 7bit Content-Type: text/plain; charset=us-ascii
Mime-Version: 1.0 NNTP-Posting-Host: anx-ana4228.deltanet.com Message-ID:
<34f64c3f.132495737@news.deltanet.com> Lines: 20 Organization: Jugglers Against
Gravity Date: Fri, 27 Feb 1998 15:52:12 GMT Subject: Wheel-Walking a Bicycle?
Newsgroups: rec.sport.unicycling From: juggler@deltanet.com (JAG) Path:
auvm!paladin.american.edu!zombie.ncsc.mil!newsgate.duke.edu!
agate!howland.erols.net!newsfeed.direct.ca!Supernews60!supernews.com!news.delt
anet.com!not-for-mail To: UNICYCLING@winternet.com Received: from
AUVM.AMERICAN.EDU (NJE origin NETNEWS@AUVM) by AUVM.AMERICAN.EDU (LMail
V1.2a/1.8a) with BSMTP id 5016; Mon, 2 Mar 1998 12:15:01 -0500 Received: from
AUVM.AMERICAN.EDU by AUVM.AMERICAN.EDU (IBM VM SMTP V2R2) with BSMTP id 1490;
Mon, 02 Mar 98 12:15:00 EST Received: from auvm.american.edu(147.9.1.2) by
icicle.winternet.com via smap (V2 .0) id xma013311; Mon, 2 Mar 98 11:19:23
-0600 Received: (from adm@localhost) by icicle.winternet.com (8.8.8/8.8.8) id
LAA13432 for <UNICYCLING@WINTERNET.COM>; Mon, 2 Mar 1998 11:19:56 -0600 (CST)
X-Authentication-Warning: icicle.winternet.com: server set sender to
owner-unicy cling using -f Received: (from server@localhost) by
icicle.winternet.com (8.8.8/8.8.8) id LAA13505 for unicycling-outgoing; Mon, 2
Mar 1998 11:20:30 -0600 (CST) Received: from icicle.winternet.com
(icicle.winternet.com [198.174.169.13]) by thalia.fm.intel.com (8.8.6/8.8.5)
with ESMTP id JAA23812 for <JohnX_Foss@ccm.fm.intel.com>; Mon, 2 Mar 1998
09:49:42 -0800 (PST) Received: from thalia.fm.intel.com (thalia.fm.intel.com
[132.233.247.11]) by fmm ail.fm.intel.com (8.8.5/8.7.3) with ESMTP id JAA00908
for <JohnX_Foss@ccm.fm.int el.com>; Mon, 2 Mar 1998 09:45:52 -0800 (PST)
Return-Path: unicycling-owner@icicle.winternet.com
