What’s the difference between Cottered and Cotterless cranks?
Cottered cranks are the older design.  There is a cotter pin through the crank to keep the crank from spinning on the axle.
Square Tapered cranks are the newer, better design (cotterless).  The axle is square and a matching square surface on the crank, keeping it from spinning on the axle.  If they aren’t kept tight, or just from wear the crank and/or the hub will get rounded, causing the crank to move on the hub.
http://unicycle.com/shopping/shopexd.asp?id=701
Thanks for the info.
man warlord, you’ve made ship loads of threads…
Simple. Cotterless = not cottered.
Did you mean What Are Cottered Cranks?
25 so far!
So what dose it matter.
I think it’s time to retire the term “cotterless” to describe square-taper cranks. ISIS is cotterless too.
no, nothing wrong with it but they made a search button for that exact reason…
I figured “cotterless” just meant they didn’t have a cotter. But it turns out that term is only used for the square-tapered hubs. So the one-piece crank on my bicycle is not called cotterless, nor are the splined hubs, etc.
“Cotterless” sounds like a positive thing, which it is, compared to cottered cranks. Only, as far as I know, nobody makes cottered-crank unicycles anymore, so now “cotterless” is the cheap generic version.
When I first joined as “Uni Tricks” I sure made alot of threads too =]
