Wanted: 26"/24" Muni
Does anyone have a 26" or 24" Muni? Preferably 26", though either will do.
Im in Richmond, VA. I have an older model KH 24" muni available. Old style black KH frame, bearings could use a lube, does not include cranks. Tire still holds air and everything still works, just needs a tune up.
If you can pick it up it’s your’s for $125?
I definitely won’t be able to pick up from Richmond any time soon, though I could ship. Does it have a way to put brakes on, and what kind of saddle is it? Also, do you think I would be able to repaint the frame?
BTW, in February/March next year I will likely be down in Richmond.
The saddle is a KH Freeride with removal seat cover. It does have brake mounts on the frame for rim brakes. You’d have to swap the hub in order to put a disc brake on it though. I’m sure that you’d be able to repaint the frame if you wanted to. I personally wouldn’t know where to begin aside from disassembly. I imagine that some sanding and stuff would also be involved.
It would be a bulky shipment, probably in the $50 market or so.
A friend of mine in Germantown MD has a 26" Hatchet for sale: Nimbus Hatchet 26” uni for sale - #2 by munimag
That’s just several miles from the Shady Grove metro station.
