I just came across this page about wheel building where it is suggested that thicker spokes be used on the right side of a bicycle rear wheel. Presumably the same idea could be applied to asymmetrical unicycle wheels with inboard disks.
I’ve never noticed wheels using two different gauge spokes but then I have never looked for it. I will be looking now.
I find it very weird that I constantly see people worrying about asymmetrical wheels and looking for fixes to their apparent instability, but I am yet to see anyone actually having any issues at all.
I used to do that with my mountain bike rear wheels, mostly to avoid spoke breakage. In theory the spokes would go slack less often, and not suffer so much metal fatigue. It worked fine, but I don’t put nearly as many miles on my unicycle wheels, so fatigue failure hasn’t really been a problem*.
But changing spoke thickness doesn’t make a symmetrical wheel; I would rather get an off-center rim and have everything be the same on both sides as far as the spokes are concerned. I have one of those on my road bike rear wheel, and I like it.
I did have a bunch of spokes fail on my Torker DX, which was a poorly made unicycle in many ways. All the breaks were in the bottom quadrant of the wheel in my normal hopping position, so it probably was from spokes going slack. I rebuilt the wheel with new spokes and never had another problem.
I’ve mixed regular and double butted spokes on a dished wheel before. Not because I figured it was a particularly good idea (though I figured it would not hurt for the reasons stated above) but because that is what I had in the right size.
Generally the rim is what limits the amount of tension you can put in the wheel, not the spokes, so I think its really more about going thinner on the slack side than thicker on the tight side.
[Following comment is by John Allen]
I recommend thicker spokes for the right side of a dished rear wheel (a wheel used with a multi-sprocket cluster) than the left side, because the left-side spokes are under lower tension. The thinner spokes on the left side will be working more nearly at the tension for which they are designed, and so they will be stretched more and less likely to go slack. For more details, see my article on spoke tension.
I had a big problem on my 26" Oracle. Unfortunately, I didn’t know enough, technically, when the problem happened to correctly identify the cause of the problem.
What happened is that the wheel started riding closer and closer to one side of the frame. This could have been in part caused by the asymmetrical wheel build. If I recall, I was spending a lot of time UPDing on hills and remounting at a 90 degree angle to the hill. I was stronger mounting with the left side of the wheel facing downhill. Many of the mounts were very rough, and I’m pretty sure this put a lot of tension on the spokes. However, I don’t know how that situation is related to the spoke-strength of the asymmetrical wheel. The same issue could have happened on a normal wheel.
I’ve built a rear wheel for my mountain bike with thinner spokes on the left side - the theory is it helps prevent the spokes that side going slack as they stretch more (so they . Don’t think I’d spoke a unicycle wheel like that - partly because the dish on an assymetric uni wheel isn’t as much as on a rear bike wheel, but mainly because doing so makes the wheel less stiff laterally and hence not as strong. That’s not a big issue on a rear bike wheel where the lateral loads are low, it’s more of an issue on uni wheels used for hopping, or anything other than just straight line riding. In fact there’s a good argument for building uni wheels with straight gauge spokes for improved stiffness.
