Im going to be selling it on ebay soon. once i get very thing ready i well put a link later to ebay. ill be asking $350 Canadian.
I can post more pictures later if you want
Upgrading or quiting?
This is Wesley from BC? I think I remember you from youtube, anyone, you are a skilled trials rider, I hope you don’t quit.
-Isaac
Thanks Isaac no im not quiting.
Its all stock parts
-Rim: New Kris Holm 19” Trials rim, 36 hole, 47mm wide, with eyelets for extra strength.
-Weight: 5.7 kg (12 lbs)
-Minimun pedal-saddle distance: 65 cm (26 inches)
-Color: dark blue with high-durability, glossy clearcoat, laser-etched logo
-Frame:7005 T6 Aluminium frame
-Hub: KH Moment ISIS hub
-Cranks: KH Moment 7075 Aluminum cranks(137mm)
-Pedals: Jim Cielencki pedals
-Saddle: Kris Holm Fusion Street gel saddle with front lift handle and removable cover.
-Seatpost: Alloy 27.2 x 300mm bolt-on style
-Tire: 19 x 2.50 Maxxis Creepy Crawler trials, black with schraeder valve, 20-inch inner tube and rim tape
-Spokes: New Black stainless steel 13G with nipple eyelets to make a stronger wheel
-Seatpost clamp: Single-bolt, aluminium Odyssey clamp.
-Cycle Weight: 12 lbs
