I am looking for a frame for a 700c road wheel that I’ve just finished. I posted a while back that I was looking for a 29" ISIS frame but I left that hub where it was and I’ve gone with a cotterless hub instead.
So I’m now looking for a frame with 40mm (or 42mm) brackets, 100mm spacing, that is tall enough for a 28.5" wheel and at least 2" wide at the crown
I’ve got the wheel temporarily mounted in a 26" Nimbus Muni frame, which has 14 5/16" vertical clearance. (Measured with the frame standing on a table, from the table top to the bottom of the seat tube.) The tire just fits so this is the minimum vertical clearance that I would need.
I’m looking for a road frame or an older, narrower, muni frame. If you have anything that might be suitable let me know.
Thanks,
Martin
