Re: Unicycling and Balance (and Flying)
How do you keep your balance on a unicycle? That’s a very good question.
Apparently good unicyclists are using their God-given talents to ride (which
means they have the ability to sense/feel things like their center of balance
easily). In terms of research into the question of what it takes to ride a
unicycle easily, there is a well- documented account contained in an 1981 book
titled How to Cure Hyperactivity by Anita Uhl Brothers, M.D., et. al where it’s
reported that a FDA approved medicine called Bonine temporarily improved the
ability to do things like ride a unicycle easily as the medicine somehow
temporarily improved the ability to balance a little. The book is available
through the national library system. Hyperactivity is an older term for
ADHD/ADD. The book by Dr. Brothers, M.D., of Berkeley, California, et al.
discusses ideas like distractibility, short attention span, paying attention,
concentration, the inner ear, hearing, balance, sensory perception, motor
movement, memory, and dyslexia. It’s the most reliable account I know which
directly addresses the idea of the balance needed to ride a unicycle or
pogostick successfully (especially for those who find the idea almost
unimaginable). Good balance is also needed to work one’s way around a sailboat
easily in a brisk wind. The ideas of unicycles, pogosticks, sailboats, planes
(flying), and roller coasters are all inner connected it seems to me.
In article <7l9fds$j76$1@nntp1.atl.mindspring.net>,
"James Short" <james_short@mindspring.com> wrote:
> I’ve been lurking here for a while, but now I think I have a good
question
> for all you unicyclists. I’m not myself a unicyclist (yet … due to
no $$,
> but have been infected with it through observing a good friend over
the past
> year or so.), so this may be a dumb question, but here goes …
> How do you keep your balance on a unicycle? Is it through sight or
visual
> reference, inner ear sense, feel, combination, or what?
> I’m curious because at one time (not too long ago) I was also a
student
> pilot (also on hold due to no $$). In one lesson, after putting on the “hood”
> to restrict my view outside the cockpit (for the “simulated instrument”
> lesson), I was asked to close my eyes, tip my head
downward, and
> tell the instructor what I thought he was doing. At first it was
easy, we
> were in straight and level flight; then I felt the plane begin to
descend
> and turn to the left. A minute or so later, we leveled off, then
began a
> right turn, and then a bit of a climb. Finally, we were back in
straight and
> level flight. Then I was told to open my eyes and remove the hood.
Turns out
> we were in a gently descending left turn the whole time, with just a
few
> bumps put it there. Turns out that without the visual reference, I
really
> had no idea what we were doing, which is why if you ever fly into
clouds or
> fog, you need to learn to trust those instruments. Your other senses
can
> easily deceive you.
> So how is it on one wheel? Has anyone tried riding blindfolded? How
was it?
> Now that I’ve asked my question, I think I’ll return to my lurking,
and see
> if anyone has a good answer …
> Thanks!!
> Jim
Sent via Deja.com http://www.deja.com/ Share what you know. Learn what
you don’t.
